Is the pcv valve supposed to be super loud?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Apr 14, 2024.
  1. Apr 16, 2024 at 5:46 PM
    #41
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Yourwelcome
    Stevie17[QUOTED] likes this.
  2. Apr 16, 2024 at 5:48 PM
    #42
    Gfenza89
    Do you feel any mild shaking in idle when in gear?
  3. Apr 16, 2024 at 9:45 PM
    #43
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    No I don’t, but I’m at almost 96xxx and they recommend changing it close to 100000. So I just consider it preventative maintenance. :thumbsup:
    Gfenza89[QUOTED][OP] likes this.
  4. Apr 2, 2025 at 7:53 AM
    #44
    chewball22
    chewball22 Member
    Tim
    2022 Tacoma Trail Edition
    Super White
    I'm at 26000 miles and I noticed my pcv making a light buzzing noise, confirmed with breaker bar stethoscope. After replacing it with new OEM valve, the old one rattled when shaking it in my hand just like the new one. The new one makes the same light buzzing noise while idling. I pinched the hose between the pcv valve and the intake while idling and it would make a hissing noise when pinched then stop when released. Would you guys say that's normal or hose connections too loose contributing to the valve buzzing somehow? Maybe it's normal...everything running fine before and after.
  5. May 4, 2025 at 11:19 PM
    #45
    donosparks234
    donosparks234 Member
    Murray, Ky
    2008 2.7 L manual Tacoma
    You can spray some ether around the areas you think may be leaking. If there is a leak your rpm’s will spike because it is combusting the ether. If no spike no leak. It’s not a huge spike but it’s enough to notice if you listen.
    chewball22[QUOTED] likes this.
