Is the RPM supposed to rise when I turn up the heating?
Discussion in '1st Gen. Tacomas (1995-2004)' started by crackedmirror, May 10, 2021.
  1. May 10, 2021 at 6:50 AM
    crackedmirror
    crackedmirror [OP] Well-Known Member
    Idles at 750. Jumps to 1000 when I turn on the heat (no matter the level).
  2. May 10, 2021 at 7:20 AM
    1997tacomav6
    Denver
    That’s what the AC does, maybe that wire is crossed or is turning on the AC with the heater on.
  3. May 10, 2021 at 7:31 AM
    Clearwater Bill
    Billy
    Largo Florida
    Open the hood and watch the AC compressor while someone turns on the heat for you.
    Betting the clutch engages.
    Also betting it's supposed to. Yea, I think it's a bit weird, but all modern vehicles seem to have this 'feature'.
  4. May 10, 2021 at 7:33 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    If you have it on the defrost setting, it runs the AC in order to dry the air (much more efficient to defrost your windshield). If you have it on another setting, the RPMs should not go up when the heat is on.
    0xDEADBEEF likes this.
  5. May 10, 2021 at 7:33 AM
    1997tacomav6
    Denver
    Your AC switch might be stuck in the on power position
