Is the software lieing to us
Discussion in '3rd Gen. Tacomas (2016-2023)' started by iShiFT559, Apr 17, 2019.
  1. Apr 17, 2019 at 10:30 AM
    iShiFT559
    iShiFT559 [OP] Well-Known Member
    2018 Tacoma OFF Road 4x4 6-SPEEDd
    Upgrade Mishimoto Weighted shift knob
    How is possible when I downshift in the MT slowing down to prepare to stop the MPG gauge show 30+ at 3k RPM foot not on gas. But when im in neutral coasting to stop the RPM is below 1k and im getting 30+ MPG also.
    Their is no possible way im getting the same MPG ? Correct...
  2. Apr 17, 2019 at 10:32 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Because the ECU cuts fuel to the injectors when in gear and coasting as the transmission is keeping the crank rotating. In neutral fuel is required to keep the engine idling.
    AxisCab, Tocamo, tonered and 10 others like this.
  3. Apr 17, 2019 at 10:37 AM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    The computer calculates the speed you are going and how much fuel is being used. While you're coming to a stop or coasting, the engine is using almost no fuel and you are still moving. The computer doesn't know you are about to come to a complete stop, just sees the numbers in real time.
    Boghog1 and iShiFT559[OP] like this.
  4. Apr 17, 2019 at 10:40 AM
    iShiFT559
    Interesting, and just blow out some veins in my brain trying to wrap my head around your answer.
  5. Apr 17, 2019 at 10:42 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    This. It's more efficient to stay in gear than it is to coast in neutral since you're still using fuel.
    tonered, Gunshot-6A and iShiFT559[OP] like this.
  6. Apr 17, 2019 at 10:43 AM
    iShiFT559
    Thank you though for your time
    Thank you also
  7. Apr 17, 2019 at 10:44 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    When you're in gear, the tires are still turning and connected to the crankshaft. Think about how you can start a manual car by pushing it and dumping the clutch in gear. But when you're in neutral, there's no external force to keep the crankshaft going so it needs to burn fuel to idle.
  8. Apr 17, 2019 at 10:45 AM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    its all relative, just like the eco light. its based on the throttle position sensor %
    its a guess at best, and it always will read higher than it actually is.
    your best bet is to calculate your own MPG
    iShiFT559[QUOTED][OP] likes this.
  9. Apr 17, 2019 at 10:45 AM
    Baerskin
    Baerskin Rocking in the Free World
    Manitoba
    TRD Sport Premium 4x4
    Stock
    Get the tin foil hats people!
    AxisCab, BSFord and iShiFT559[OP] like this.
  10. Apr 17, 2019 at 10:45 AM
    iShiFT559
    Awesome guys, TW is great. Hope this will help others who are like me. :alien:
    rlx02[QUOTED] likes this.
  11. Apr 17, 2019 at 11:10 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Efficiency, which mpg is a measurement, has nothing to do with engine rpm and everything to do with the power required from the engine.
    An example would be driving unloaded in 4th gear at 4000 rpm versus pulling a 6K trailer at 2000 rpm.
    Which will need more power?
    Taking this one step further...
    Engines, motors and other rotating devices are designed to be most efficient in a range of rpms. What this means is your engine at a real low rpm or a real high rpm uses more energy simply to function than it does in the efficient rpm range.
  12. Apr 17, 2019 at 11:17 AM
    muffyinva
    muffyinva Well-Known Member
    Reid
    Lynchburg, VA
    2019 Cement Tacoma DCSB OR
    RPM's don't affect MPG, it's how much throttle you are giving.
    iShiFT559[OP] likes this.
  13. Apr 17, 2019 at 11:24 AM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
  14. Apr 17, 2019 at 11:28 AM
    ArmandHammer83
    ArmandHammer83 This truck is AMAZING
    Raymond
    Alabama
    2018 Tacoma AC V6 MT 4x4
    none yet
    as far as your actual question at the end...no you can't get 30 MPG's but putting it in neutral or when switching gears... the MPG's shown are based on the tank not the trip, unless you reset the whole thing each time you start the truck ( which is a waste of time)...all in all drive the truck and enjoy it don't worry about MPG's because if thats a concern sell the truck and get a bike of your choosing
  15. Apr 17, 2019 at 11:46 AM
    iShiFT559
    Not concered about MPG, im now downshifting to avoid the driveline clunk in neutral and noticed the MPG meter showing the same as neutral coasting. Thank you everyone.
  16. Apr 17, 2019 at 11:48 AM
    ArmandHammer83
    Raymond
    Alabama
    none yet
    hey Op, so basically a observation post, gotcha...yeah i downshift when i slow down or come up to a speed bump to avoid the driveline clunks also, saves the brakes too so win-win
  17. Apr 17, 2019 at 1:58 PM
    personalt
    personalt Well-Known Member
    I noticed this with radar cruise control on the auto. When the guy in front of me moves out of the way it sometimes double downshifts to accelerate to get back up to speed. . However I would find that as it got back up to selected speed it would often hang out in that low gear even though you would expect an upshift. The engine would remain at 3,500 RPMs+ and loud but the MPG meter would shoot as made speed and stopped accelerating.
  18. Apr 18, 2019 at 8:42 AM
    btcca4
    btcca4 Well-Known Member
    ECU reading high vacuum too. Deceleration.
  19. Apr 18, 2019 at 3:32 PM
    Jim1946
    Jim1946 2020 TRD Sport 4X4
    San Francisco Bay Area
    2020 TRD Sport 4X4
    Also dangerous to coast in neutral as you give up some vehicle control.
