Is the "Strawberry Milkshake" an issue for us or for some reason is it just the 4Runners?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ROCKIN RICHIE, Apr 30, 2016.
  1. Apr 30, 2016 at 3:49 PM
    ROCKIN RICHIE
    ROCKIN RICHIE [OP] Well-Known Member
    BEAN TOWN
    02'TACO
    I currently have 165,000 with original radiator. I do coolant replacement every 30,000 and have used only distilled make-up water. I have seen Avalons with this issue at only 70,000? I t seems galvanic corrosion where line enters tank is the culprit. Yes, I'm aware of external cooler to bypass but I want cooling while sitting in traffic as well as winter warming capability. Have any of you had enough concern to do a pre-emptive strike and just change out a seemingly good radiator? The milkshake could terminate my 15 year perfect affair with my truck. Thanks for your input.
  2. Apr 30, 2016 at 4:16 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Yet to hear of it happening on a taco yet.
    If your worried then spend a few bucks on an external oil cooler and just swap the hoses over and cap off the factory radiator.
  3. May 1, 2016 at 1:13 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It can happen to any vehicle that uses the radiator as a dual purpose cooler coolant and transmission fluid do not play well together .
    Worried about things not warming up in the winter you can install a temperature controlled solenoid .
    Not enough cooling stuck in bumper to bumper crawl a simple matter to add a electric fan it can be manual or electrically controlled .
    Simple solutions to your major concerns!!
  4. May 1, 2016 at 9:05 AM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    There's a good write-up here on TW somewhere. Just search it. Basically the 4Runner and Tacoma radiators are made with different materials. The Tacoma's are a little better materials but as Wyoming09 stated, any vehicle with a dual purpose radiator is susceptible.
