Is the tundra brake upgrade worth it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Just_Tombo, Apr 26, 2021.
  1. Apr 26, 2021 at 9:45 PM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    He has the snowflake wheels so he'll be fine with the big 13WL calipers. I had the same wheels.
  2. Apr 26, 2021 at 10:22 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    My fat ass truck loaded up with supplies for 1-2 weeks of camping weighs 5700 pounds.
    I had serious brake fade 2 times with the stock brakes. So far after 3 years with the Tundra brakes there has been no brake fade.
    1997tacomav6 likes this.
  3. Apr 27, 2021 at 5:56 AM
    Just_Tombo
    Just_Tombo [OP] Well-Known Member
    2003 prerunner TRD DC 3.4
    Thanks for all the replies y'all!
    One question that pops up - 199 vs 231 rotors... Which one is the stock tundra rotor? The 231?
  4. Apr 27, 2021 at 6:00 AM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I've got a '96 4x4 with 414,000 miles that I've been driving for 25 years under about every condition imaginable and brakes have always been completely adequate.
    Can't imagine upgrading to another system unless you are completely bored needing something to do and have more $ than you know what to do with.
  5. Apr 27, 2021 at 7:14 AM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    Toyota used both. The older models use 199's and the newer ones (2004-2006, I believe) use 231's. I have a 2006 Double Cab Tundra and its's using the 231's (13WL) so I just copied that and used it on my Tacoma.
    unstpible and Which Way Out like this.
  6. Apr 27, 2021 at 8:45 AM
    Just_Tombo
    Thanks! And will either fit in my 16" snowflake rims? Thanks again.
  7. Apr 27, 2021 at 8:48 AM
    Nano909
    Xcab 3.4 4wd 5MT
    Scroll up and read
  8. Apr 27, 2021 at 9:16 AM
    Just_Tombo
    I see you pointed out the caliper, and i guess the 199 and 231 use different calipers?
  9. Apr 27, 2021 at 9:21 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Same here. My 2001 DC's brakes have been pretty impressive in some hairy situations over 20 years. They always felt like "upgrade" to me.
  10. Apr 27, 2021 at 9:30 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Fwiw, I have the opposite opinion. On 32s with a little weight, I’ve been uncomfortable more than once with the capability of stock brakes, especially while towing. I’m doing tundra brakes very soon
    unstpible, Ritchie and frizzman like this.
  11. Apr 27, 2021 at 9:30 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    The rotors are the same, it's the calipers that are different and the 199 vs. 231 refers to the surface area of the pads. The 13WE are 199 and 13WL are 231. You want the 13WL.
    Everything you need is in the information I posted earlier. There's more in the linked threads there that will answer any question you have. Seriously.
    Here is my original reply in this thread: https://www.tacomaworld.com/threads/is-the-tundra-brake-upgrade-worth-it.718801/#post-25585920
    Here are the links that will answer any other questions you have about this:
  12. Apr 27, 2021 at 9:44 AM
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    10000% worth it. I used to destroy OE pads and rotors.
    I was doing less than 10k miles before they were toast. I'm a super conservative driver too...
    When you have heavy tires, camper, armor, etc you need larger pads and rotors that can handle the abuse.
    If your taco is stock, then I'm not sure its worth it.
    unstpible and Just_Tombo[OP] like this.
  13. Apr 27, 2021 at 9:50 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I've daily driven my truck on 33s, RTT, rack, steel bumpers + swing out, sliders, skids, etc....have had the same stock pads/rotors on for the last 40k miles and they still have life left :notsure:
    I'm guessing being manual has something to do with it and downshifting to help slow down rather than simply braking all the time.
    unstpible likes this.
  14. Apr 27, 2021 at 9:52 AM
    frenchee
    Oceanside CA Area
    Or you drive on flat road all the time.
    Doing a lot of downhill in an auto and crappy gear selection with the auto kills the pads fast.
    unstpible and otis24 like this.
  15. Apr 27, 2021 at 9:52 AM
    #35
    eon_blue
    Azusa, CA
    I live in CA I assure you that is not the case lol.
    otis24 and frenchee[QUOTED] like this.
  16. Apr 27, 2021 at 10:53 AM
    #36
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    just my opinion here. If towing and or bigger wheels and added weight probably worth upgrading. But for stock weight and minimal or light towing I suggest to check rear drum brake function before deciding . I bet a lot of trucks don't have any rear brakes as the auto adjusters (star wheels) don't usually work. After I tightened up my rear drums, I thought the brake performance was fine.
  17. Apr 27, 2021 at 8:29 PM
    #37
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    I got the kit on Amazon for about $320 a few years ago...still had the stock rotors and calipers on the truck...so figured either way it was time to change at least the rotors, its definitely worth it. All new fresh components are always great. If it cost six or seven hundred I'd say prob not, but for a little over $300 you can't beat it.
  18. Apr 27, 2021 at 9:16 PM
    #38
    Bmann88
    Bmann88 Member
    Bruce
    2001 Tacoma Extended Cab Jade Geen Mica
    Tundra Front Brake upgrade, Nitro Helical Worm Gears LSD, Nitro 4.88's Front and Back.
    The Tundra brake upgrade is a night and day difference!
  19. Apr 28, 2021 at 3:04 PM
    #39
    Boone Wesley
    Boone Wesley Well-Known Member
    Boone
    LA 818
    01 4D 4WD Limited
    Second best mod after Kings
  20. Apr 28, 2021 at 3:12 PM
    #40
    1997tacomav6
    Denver
    1)Supercharger
    2) kings
    3) projector headlights
