Is the window channel run replacement for a 2008 toyota tacoma the same LEFT and RIGHT?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrw2008, Nov 7, 2024.
  1. Nov 7, 2024 at 3:50 AM
    mrw2008
    mrw2008 [OP] New Member
    2008 Toyota Tacoma trd access cab
    I need to replace the rubber for the window channel but the Left hand side replacement has a different number and has been on backorder for forever.
    Is the rubber the same on both sides or are the LEFT AND RIGHT different? Can I use a right channel run replacement instead?
    Thanks
