Is there 1" spacer lift available?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TL697, Feb 4, 2010.
  1. Feb 4, 2010 at 7:32 PM
    TL697
    TL697 [OP] Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    I want approx. 1" of lift in the front...
    I realize most people just get 5100's and set them at either .85 or 1.75, but I think a 1" spacer would work just fine... I had the TSB springs done and don't want to completely level the truck (I want just a tad of rake so that it sits level while towing...) If I buy the 5100's, I woud set them at .85...
    I did a search and couldn't find anything...
  2. Feb 4, 2010 at 7:33 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    How about a hockey puck?
  3. Feb 4, 2010 at 7:42 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    try Ebay mabey.
    search: tacoma lift kits
  4. Feb 4, 2010 at 8:35 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Never saw such an animal. Closest I've seen to 1" is the .85 Bilstein.
  5. Feb 4, 2010 at 8:37 PM
    TL697
    Jacksonville, FL
    Yeah, that's what I'll probably end up with...
  6. Feb 4, 2010 at 8:43 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    they are very simple, if you can figure out the correct inner and outer diameters and any other measurements you mayn need, any machine shop with a lathe will be able to make thim in less than an hour
  7. Feb 4, 2010 at 8:46 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I've seen 1.5" on e-bay
  8. Feb 4, 2010 at 9:52 PM
    delscorcho
    delscorcho Well-Known Member
    Yorba Linda
    09 DC LB SR5, Black Sand Pearl
    30% Tint, Weathertech Floor Liners, Transmission TSB, Leaf Spring TSB, 1" Front lift, FJ Alloys, 265/70/17
  9. Feb 5, 2010 at 12:37 AM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    fatbobs garage sells some polyurethane spring cushions that will give you exactly 1 inch. I am using them now. They are great.
  10. Feb 5, 2010 at 3:57 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Try toytec top plate spacer's! They should work just fine for what you are looking to accomplish!
  11. Feb 5, 2010 at 5:20 AM
    Burns
    Burns Excellent Member
    NJ
    17 DCSB Off-Road
    None!
    I have the Eibach springs on my stock billys and I have about 1 inch of lift. Pics are in my gallery.
  12. Feb 5, 2010 at 7:40 AM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Are you talking about the coil spring isolators? Measures 1/2" but gives 1".
  13. Feb 5, 2010 at 8:56 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    If your going to be running the bilstein shocks, we don't recommend the use of the top plate spacer.
    The shock length is extended so adding a top plate spacer could cause the coil spring to hit the upper control arm because of increased down travel. The down travel would be increased more than we recommend too so damage could occur to ball joints, springs and CV axles.
    [FONT=&quot]
    [/FONT]
  14. Mar 10, 2010 at 11:06 PM
    sincitytaco
    Las Vegas
    My 5100s were exactly the same length as the OEM bilsteins. I am running a 3/8" top plate spacer on the driver side and it is close, but does not hit the coil at full droop.
  15. Mar 11, 2010 at 9:40 AM
    Toytec Lifts
    Rocky Mountains
    The 5100's are about 1/2 inches longer than your stock OEM Bilsteins are, or from what we have measured.
  16. Mar 11, 2010 at 9:45 AM
    sincitytaco
    Las Vegas
    If they were longer then you have binding issues, especially with the stock UCAs. Not to mention if they were longer you would get less up travel because the coil perch would need to be moved up and to make them longer they would have to be lengthened form the bottom of the shock. This would be of no benefit.
    Trust me, they are exactly the same length.
  17. Mar 11, 2010 at 9:57 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I'm running Eibach 1.6" coils, 5100's at 0.85", a 1/2" top spacer on the driver's side, and a 1/4" spacer on the passenger side. Quite the cocktail!
    Mathematically it should give me over 3" of lift. I ended up with 2.75" on each side. I'm still running stock UCA's. At full droop they touch the coil but just barely. Aside from a tiny spot of rubbed paint, I can't see any harm. I plan to go to aftermarket UCA's in the next few months.
  18. Mar 12, 2010 at 6:14 AM
    Toytec Lifts
    Rocky Mountains
    So I happened to be going to the shop last night, so the owner and I decided to take a few pictures to show you the lengths.
  19. Mar 12, 2010 at 10:13 AM
    sincitytaco
    Las Vegas
    wholly crap, according to your pics it looks as though it is about 1/8-1/4 inch longer.
    When I did the same thing I must have mis-measured because they were the same. Nice pic and info. I guess I am wrong.
  20. Mar 15, 2010 at 4:44 PM
    Toytec Lifts
    Rocky Mountains
    It was actually reading just under a 1/2 inch difference.
    Just wanted to share. :)
