is there 5volts
Discussion in 'Audio & Video' started by dan0, May 11, 2011.
  1. May 11, 2011 at 5:49 PM
    dan0
    dan0 [OP] Well-Known Member
    swamplands of sc
    Sold 2011 Prerunner Doublecab 4cyl auto
    is there 5 volts running around in the tacoma anywhere?
    I tried a search but "5" is not allowed :rolleyes:
  2. May 11, 2011 at 5:59 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    Probably not unless it is a reference signal to a sensor in which case i would not mess with. What would you need a 5v line for?
  3. May 11, 2011 at 6:03 PM
    PatSully
    PatSully Well-Known Member
    Pat
    Phoenix
    07 Access Cab TRD O/R
    Rear AAL, Extra D-Rings
    if it is for a satellite radio, i just installed this little magic box.
    now i dont have that darn little plug in my cigarette lighter
  4. May 12, 2011 at 5:18 AM
    dan0
    swamplands of sc
    no, I want to make my on MP3 charger.
    that sirius charger is very reasonable at 19.99 vs grom boxes, i-toys etc
    I'll probably just use one of these ( I already have some)
    http://www.radioshack.com/product/index.jsp?productId=2062599
    if i can find a place to bolt it to the frame under the dash that will take care of heatsink and ground.
    anyone know of any issues with my idea let me know thanks
    dan0
  5. May 12, 2011 at 2:11 PM
    lbridges
    lbridges Well-Known Member
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Why not use one of the two cigarette lighter type outlets and a USB charging plug?
  6. May 12, 2011 at 2:57 PM
    dan0
    swamplands of sc
    where can i find one under $5.00 bucks
    or dont stick out of the lighter socket 4 to 6 inches ?
  7. May 12, 2011 at 3:27 PM
    lbridges
    Lee
    Indialantic, FL
    '11 PreRunner SR5
  8. May 12, 2011 at 5:12 PM
    dan0
    swamplands of sc
    thats cheap enogh but it is ugly
    I'll have to give it some thought
    cheap, ugly and quick
    or
    cheaper, better looking but might be awhile before i have the free time
    hmmm...
  9. May 12, 2011 at 5:38 PM
    lbridges
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    I actually like the 5V regulator you planned above (lots more stealth install possibilities while preserving the outlet), but make sure in your design you can deliver 1000mA as shown in the Amazon model. Some people have jumped on parts that only support half that (the USB spec), but Apple products (and others, don't know) may not properly charge with less than an amp delivery. Not saying you didn't already think about it, offering "just in case".
  10. May 12, 2011 at 6:09 PM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    why not cheap + Stealth + you know it works?
    buy a cheap charger like lbridges linked above. Then hardwire it behind the dash, and run a short USB extension plug to a blank spot, or put in a female USB port somewhere in the truck.
    A bit more work, but will look great, be stealth, and fairly simple to install.
