Is there a 12v wire behind back seat I can connect a dash cam to?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TucsonAZ, Apr 13, 2018.
  1. Apr 13, 2018 at 4:35 PM
    TucsonAZ
    TucsonAZ [OP] Well-Known Member
    2006 Crew Cab TRD
    ARB Bumper
    I happen to now have two dash cams so I figured I would just put one on the rear window. I am just wondering if there's a 12v power source back there that is switched with the ignition. Or actually, I'm sure there is so I'm wondering if any of you have hunted one down that works well and don't mind sharing your secret.
    Thanks a lot!
  2. Apr 13, 2018 at 8:24 PM
    caribe makaira
    Caribbean, Puerto Rico
    If you have the audio with separate amp, you're in luck. There is a connector you could piggie into.
  3. Apr 14, 2018 at 2:07 AM
    TucsonAZ
    2006 Crew Cab TRD
    ARB Bumper
    I do happen to have the JBL setup, do you know where it is by chance?
  4. Apr 14, 2018 at 5:18 PM
    caribe makaira
  5. Apr 14, 2018 at 6:07 PM
    TucsonAZ
    2006 Crew Cab TRD
    ARB Bumper
    Thank you, you're amazing, that's perfect!
  6. Apr 15, 2018 at 6:20 PM
    caribe makaira
    Show us what you did...:burp:
  7. Apr 15, 2018 at 7:57 PM
    TucsonAZ
    2006 Crew Cab TRD
    ARB Bumper
    My list of projects right now is OVERWHELMING!!! This is on there but it's going to be a month before I get around to it due to some changes to my travel plans for the year. I will post though when I can, I never forget but everything takes me awhile.
