Is there a 4" lift kit for a 2011
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bsteinkamp, Mar 10, 2011.
  1. Mar 10, 2011 at 12:33 PM
    bsteinkamp
    bsteinkamp [OP] Well-Known Member
    Bruce
    Memphis
    2011 TRD Sport
    6" Fabtech Lift LR UCA's Terra Grapplers 285/70/17 American Racing Wheels 17X9 Wind Deflectors
    Looking for a suspension lift kit greater than 3" but not a 6" is there anything out there?
  2. Mar 10, 2011 at 12:35 PM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    No suspension lifts by themselves will take you over 3"... Even at 3" your CV angles are ridiculous in most cases. What's your primary use for the truck?
  3. Mar 10, 2011 at 12:36 PM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    Dirt king 3.5 LT kit with kings, 4 link rear with foa, 4.56 gears, Detroit and arb lockers, one piece drive shaft, armor, and some other things.
  4. Mar 10, 2011 at 1:57 PM
    bsteinkamp
    Bruce
    Memphis
    2011 TRD Sport
    I'm looking to go off road just want the front higher than my current 3" spacer lift.
  5. Mar 10, 2011 at 2:00 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Just get bigger tires you will gain ground clearance that way.
  6. Mar 10, 2011 at 2:02 PM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    if you have 4x4 rcd. if you have a prerunner then spindles.
  7. Mar 10, 2011 at 2:02 PM
    Sport11
    Sport11 Well-Known Member
    Kingsport, TN
    Dodge Ram 1500
  8. Mar 10, 2011 at 2:08 PM
    bsteinkamp
    Bruce
    Memphis
    2011 TRD Sport
    I've got a 4 X 4 TRD Sport package.
  9. Mar 10, 2011 at 2:09 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    then rcd
  10. Mar 10, 2011 at 2:09 PM
    bsteinkamp
    Bruce
    Memphis
    2011 TRD Sport
    I've got 285/70/17 on currently.
  11. Mar 10, 2011 at 2:10 PM
    bsteinkamp
    Bruce
    Memphis
    2011 TRD Sport
    That's the only option?
  12. Mar 10, 2011 at 2:10 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    RCD Lift then.
  13. Mar 10, 2011 at 2:10 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    yes
  14. Mar 10, 2011 at 2:13 PM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    This then....I am sorry. I am drunk.
  15. Mar 10, 2011 at 2:13 PM
    JLee
    Jerry
    Bay Area NorCal
    yep RCD drop bracket but you will lose ground clearance just toss some 35's on and you will be much happier
  16. Mar 10, 2011 at 2:15 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    35's would be pretty tough to fit. he would probably have to get an off road bumper.
  17. Mar 10, 2011 at 2:19 PM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    Well... It's not the only option. You could do 3" susp lift and then your spacers if you wanted to go that route. I advise against it, but it is in fact an option...
  18. Mar 10, 2011 at 2:23 PM
    bsteinkamp
    Bruce
    Memphis
    2011 TRD Sport
    RCD lift it is thanks all.
  19. Mar 10, 2011 at 2:25 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    you'll love it
  20. Mar 10, 2011 at 2:33 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    Yeah RCD will get what you're looking for.
    But for the record, if you were a prerunner, the OME 886 with top plate spacer will get you a 4" lift.
