is there a 6 inch lift you dont have to cut the body mounts for?
Discussion in 'Suspension' started by Kenpo, Nov 9, 2012.
  1. Nov 9, 2012 at 5:44 PM
    Kenpo
    Kenpo [OP] Member
    kauai, hawaii
    stock for now
    i been looking around, everyone seems to tell me to stay away from tuff country and fabtech, i live in hawaii everyone loves fabtechs, i havent heard much good about them on the internet, and i am trying to stay away from cutting or welding, dont go in the mud much, more on the sand my budget as far as a lift kit goes is about 3500 any personal experiences would be greatly appreciated on does and donts of what lift to buy, i dont plan on doing any serious wheeling with it, but i do want decent clearance, 2012 6 spd 4wd
  2. Nov 9, 2012 at 5:46 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    with a drop bracket lift, there will be cutting, and you will have less clearance than with a 3 inch lift.
    have heard good things about pro comp?
  3. Nov 9, 2012 at 5:53 PM
    Kenpo
    Kenpo [OP] Member
    kauai, hawaii
    stock for now
    yeah ive been looking up procomp but i think i remmeber seeing you have to cut the body cab mounts, and drop bracket is basicly just the spacer that goes from the frame to the lower a arm?
  4. Nov 9, 2012 at 6:01 PM
    97yota4wd
    Eric
    Mesa, AZ
    im not sure on the body mounts, and yes i guess you can call it a spacer, it drops the differential down lower so you can still have 4wd.
  5. Nov 9, 2012 at 6:06 PM
    Kenpo
    Kenpo [OP] Member
    kauai, hawaii
    stock for now
    so pretty much procomp is what you would suggest? i was looking at the stage 2, i see people say they find stage 2 kits for 1500, and even as low as 1000 dollars but i just cant seem to find them, i mean i have a bigger budget but i wouldnt mind saving 500,or even 1000 dollars would go to some nice bumpers...or other goodies?, i also was looking into chaos, any thoughts on that?
  6. Nov 9, 2012 at 6:12 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    All will require cutting for 4WD
  7. Nov 9, 2012 at 6:40 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    There is no cutting of body mounts for these kits. With a 4x4, u will have to cut a section out of the frame/cross member. And there are no stage 2 kits for $1500 to $1000 unless its used.
  8. Nov 9, 2012 at 6:43 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Keyser West Virginia
    2010 white double cab
    8 inch alcan custom leaf packs, ome 885's powdercoated white, bilstein 5100's all the way around with 12 inch travel on the rear, Light Racing Upper Control Arms, Sway bar removed, 17x9 kmc strike. 35x12.50 nitto Trail Grapplers. Satoshi Grill made by (homertaco), Black Headlight housings,retrofits, Tinted Tailights, color matched grill, Bought a TRD sport hood,elite off road front plate bumper,elite off road sliders, 13% tint on the front windows, 5% on top of the facotry rear windows and back glass, 5% tint stip across the windshield, Lo Pro Truxedo tonneu cover, Herculiner bed liner, Weather Tech Window Visors, Exhaust- Flowmaster Super 44 dumped above rear axle, Maglight Mount on side of drivers seat, Scangauge II, Mossy Oak Camo Seat Covers, Weather Tech Floor mats, Spatter painted A-Pillars, Spatter painted headunit trim and shifter trim, Headunit= Pioneer 4300 double din touch screen, Speakers- Precision Power 3 way component stage, Precision Power 8 i
    you will not find a stage 2 kit for that price. pro comp stage one is 1500-1600 and stage 2 2500-2600 the last time i looked. you also dont need to cut the body mounts unless you are going to run a 35" tire. you will rub it then. the piece you do have to cut is a piece out of your rear crossmember for your front drive shaft to come through. the piece you need to cut is about 4-5 inches long
  9. Nov 9, 2012 at 6:56 PM
    Kenpo
    Kenpo [OP] Member
    kauai, hawaii
    stock for now
    thats what i figured on the price, and for the bodymounts if i can scoot away on 33's and no cutting then i think thats the way to go...to bad my truck wont beable to fit in my garage after this :(, what suspension do you have on your truck white taco*?
  10. Nov 9, 2012 at 7:05 PM
    Kenpo
    Kenpo [OP] Member
    kauai, hawaii
    stock for now
    i was also looking, is it really worth the 1000 dollars extra for the stage two procomp shocks? or should i get the stage one and just get a different pair of shocks? or i guess what im asking is there better bang for the buck shocks out there rather than use procomps
  11. Nov 9, 2012 at 9:24 PM
    Warputer
    2011 TRD Off Road
    A few guys on here have said that the Pro Comp coilovers are not worth it....better off with a Stage 1.
  12. Nov 9, 2012 at 9:27 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    I believe that the stage 1 kit will not give you the full 6" lift. But since you're thinking about 33" tires it will be fine. As for cutting the cab mounts? Depends if you plan on stuffing the tires while turning? Even the stock tires can rub the cab mounts.
    (There's other factors involved)
  13. Nov 9, 2012 at 10:30 PM
    Kenpo
    Kenpo [OP] Member
    kauai, hawaii
    stock for now
    the only reason im thinkn of 33s is to get away with the cutting actually...if i could id use 35's, but getting abit off topic...what lift would be the best bang for my buck as far as 6 inch lift being good for offroad, but not like riding a horse on the high way
  14. Nov 9, 2012 at 10:35 PM
    Blacktacoma23
    2011 Mall Crawler
    Stg 1 and add some Coilovers for a 6" lift (Icon, King, Fox)
    New springs in the rear so no blocks.
    If your cutting the cross member for a DB then cutting cab mounts for 35's is worth it
  15. Nov 9, 2012 at 10:59 PM
    Kenpo
    Kenpo [OP] Member
    kauai, hawaii
    stock for now
  16. Nov 9, 2012 at 11:02 PM
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    Didn't know there was such a thing? Heh heh....
    I would say go for a quality 3in lift, same or more ground clearance as a 6in, no need to cut out a cross member. If you can't be swayed from a 6in, get the stage 1, then buy some good coil overs and new rear leafs so you don't have to run blocks. Anyways, my 2 cents.
    I see so many DB lifts here in Hawaii but most of those trucks never even see dirt sadly, all show.
  17. Nov 9, 2012 at 11:03 PM
    mutilatedjak
    WA
    Drop bracket or a product used for feminine hygiene heh heh, but here at TW, normally the former.
  18. Nov 9, 2012 at 11:04 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    your going to be cutting the crossmember regardless of 33s or 35s, db = drop bracket
    get the stage 1 then buy kings
  19. Nov 9, 2012 at 11:41 PM
    Kenpo
    Kenpo [OP] Member
    kauai, hawaii
    stock for now
    i dont care about cutting the other parts needed crossmember etc, i just dont like the idea of cutting a suppor for the body mounts, ive lifted an 89 toy before, wasnt that big of a deal, i was just going for the one you have to modify the frame the least.... if i have to do enough cutting and welding i wont mind going the extra mile and just putting a 44 under it...
  20. Nov 9, 2012 at 11:44 PM
    Kenpo
    Kenpo [OP] Member
    kauai, hawaii
    stock for now
    yeah im definatley getting springs, doing away with my stock springs in the back, im fed up with the wheel hop, and i figured that was gunna be the best bet was stage 1 with better shocks, i was also looking at total chaos lifts, seen anyone with that? hows that working for them? seen any 6 inch chaos lifts around? i can only find 3 inch
