Is there a basic chip that will run our engines lean(er)?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cliffhucker, Apr 19, 2011.
  1. Apr 19, 2011 at 9:35 PM
    cliffhucker
    cliffhucker [OP] Active Member
    sam
    idaho
    10' Tacoma SR5 TRD Off Road
    Weather-Tech
    I keep hearing that our trucks run rich, meaning they inject more fuel than is necessary. I am aware of the URD computer modules which manually allow you to specify fuel mix etc. but what if all I want to do is lean out the fuel/air mix to run most efficiently fro mpg? Is there a RELIABLE chip or something that will lean it out a bit? I've also heard that messing with the fuel/air ratio will mess things up when dealing with altitude but it seems to me that if the ratio is just lowered then it would do fine. Our current ECU has a set ratio, and doesn't have issues with altitude changes, as long as the ratio remains constant.
    I fully expect to hear "if you wanted gas mileage why did you buy a truck?" However, I love and need my truck, and I am willing to pay the price for the gas it sucks, but I am still interested in getting the most out of it.
    I recently added a TRD cat-back exhaust, afe pro-dry filter, and an ecosystems fuel enhancer, all the while driving super conservative and going easy on the gas. I've noticed a legitimate power increase and throttle response, and I have gotten my mpg up to about 23 mpg (just highway). 21 going 80mph on highway and some in town driving and towing a snowmobile.
    By all means this is great, but I would love to go for a bit more. Are there any options (chips) available that don't require a dyno test and all that jazz, just something simple to lean it out.
    Thanks, and I've been searching for this a while... But If there is another thread feel free to direct me to it.
  2. Apr 19, 2011 at 9:38 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
  3. Apr 20, 2011 at 3:32 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    I thought the Volant made it run "lean" not rich? No?
  4. Apr 20, 2011 at 4:27 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    These things have closed-loop engine management that's optimized for lean burning... for pollution control. If you DO somehow manage to make it run leaner you're gonna do damage to the engine.
  5. Apr 20, 2011 at 2:49 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Yes I know that, :) but I have read more then once that the Volant CAI makes the 1GR's run lean, meaning it doesnt get enough fuel and to much air for a ideal a/f. Thats what I have read all though I have seen no proof. Just makeing sure that no one gets the wrong info because I have heard it was lean, not rich. ;)
  6. Apr 20, 2011 at 4:42 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    It is programmed to run properly. When you screw with the mix, you f stuff up. Too lean and you run hot, as well as throw codes for cat and fuel mix.
    The mix is not too rich, it's just rich enough to keep the cat burning excess fuel. Compare it to an old Jon-e handwarmer. It only took an ounce of naptha to keep it hot for eight hours. Between the exhaust heat and unburned fuel, it won't take much to keep it hot.
  7. Apr 21, 2011 at 1:35 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Okay that makes since. I guess where I read it from was wrong. :p
