Is there a better oil drain gasket?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by maileboy, Mar 3, 2020.
  1. Mar 3, 2020 at 2:59 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Usually they give you an aluminum washer. If you want something better than that it is my recommendation that you use a drain plug crush washer made by Nissan. Those things are awesome.
    Bottman and jcayce like this.
  2. Mar 3, 2020 at 3:27 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    When the gaskets stick to the oil pan as they often do it can be a pain in the ass removing them and 'IF' you don't remove every piece then they can cause the new gasket to leak. I've been changing oil in multiple vehicles for about 44 years and have rarely replaced an oil drain plug gasket and have NEVER had one leak. I can't even imagine how many times I have changed oil in my 414,000 mile '96 Tacoma.
    Even in the SMALL chance one does leak, it's only going to drip slightly. If that happens I will notice in my drive and and address it. It's not like the drain gasket is going to disintegrate and dump all 6 quarts, blowing up the engine. And it's not going to eventually make my oil pan bolt loose by reusing it as I will replace it long before it gets to that point.
    Tacoma1845 and Tullie D like this.
  3. Mar 3, 2020 at 3:47 PM
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    Awesome, then keep reusing your gaskets. I've never had one stick on any machine and it's about 25 cents to replace. Comes off easy.
  4. Mar 3, 2020 at 5:55 PM
    jcayce
    jcayce Well-Known Member
    Texas
    17 DCSBTRDOR4X4
    Agreed. I think the last batch I got were copper.
    Bottman likes this.
  5. Mar 3, 2020 at 6:22 PM
    nomnomtaco
    nomnomtaco Well-Known Member
    2019 Black Tacoma Limited
    Hot Stock
    You are using knockoff washers.
