Is there a CARB approved super charger or turbo charger for 3RZ-FE(2.7L)?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lil'John, Jan 3, 2024.
  1. Jan 3, 2024 at 5:16 PM
    Lil'John
    Lil'John [OP] Active Member
    2002 Tacoma TRD 4wd
    Title is basically it.
    I live in the 'wonderful' state of California so I have to worry about CARB compliant devices when modifying smog test required vehicles.
    I know the 3.4L has one.
  2. Jan 3, 2024 at 5:44 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Lil'John[OP] likes this.
  3. Jan 3, 2024 at 5:52 PM
    Lil'John
    2002 Tacoma TRD 4wd
    Thank you for the link.
    FWIW, newer than first gen Tacoma is out of the question. Zero care for the looks on any of them.
    Out of curiosity, how much does it kill mpg?
    Nano909 likes this.
  4. Jan 5, 2024 at 7:23 PM
    Angel707
    Angel707 Well-Known Member
    Angel
    I get about 15 mpg but if you take it easy you can get good mpg, and by personal experience the 2rz/3rz supercharged is faster than the v6s hes talking about if you upgrade the pulley
    Diablo169 likes this.
  5. Jan 6, 2024 at 7:29 AM
    w8tdstrgecube
    w8tdstrgecube Well-Known Member
    Brian
    Wisconsin
    2004 Gold Regular Cab 2.7L Manual 4x4
    How was the install? I’m considering this for when I eventually have to rebuild my 3RZ. You have any issues with pinging? Using piggyback computer or stock ECU?
  6. Jan 6, 2024 at 3:17 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Is an engine swap possible? You could always toss in the 3.4 for more power idk how that would work with emssions thought but it would meet emssions but the paperwork might not match.
  7. Jan 14, 2024 at 6:18 PM
    Angel707
    Angel
    The install was trouble some but doable, pinging doesnt happen unless you give it too much gas below around 2.5k rpm. Im using the stock ecu with smaller pulley from lce and fuel upgrades, so far have been fine no cels or any problems of any sort still runs good despite what other people might say about the stock ecu not being able to handle the smaller pulley.
