Is there a difference between a 4x4 motor and a 2wd motor?
Discussion in '1st Gen. Tacomas (1995-2004)' started by t.hornstra, May 5, 2009.
  1. May 5, 2009 at 11:20 PM
    t.hornstra
    t.hornstra [OP] Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    i hav a 2002 prerunner, and thers someone parting out a v6 4x4 near me. i have been wanting to do a swap and im wondering if its possible to swap a manual 4x4 v6 into a prerunner that had a 2.7L auto.
    any help!?
  2. May 5, 2009 at 11:26 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    it sounds like a ton of work. first will it fit, if it does youll need diff. motor mounts, youll need his ECU, will the tranny match your drive shaft
  3. May 6, 2009 at 4:16 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It'll be a lot of work.....
    Are you keeping the auto tranny you have now?
    The things that come to mind (Burgman mentioned), are matching the engine up to your auto tranny. Bellhousing, & splines come to mind. Motor mounts and *will it fit* in the engine compartment without having to relocate other shit that's already mounted in your engine bay....etc.
    How old is your truck?
    Have you thought about trading or selling and buying a V6?
  4. May 7, 2009 at 6:09 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    Mine is a 2002, the engine is a 2004
    i would like to keep my auto tranny.
    i have thought about trading to a v6, but ive put over $700 in stereo equipment, as well as a 3inch lift and new wheels/tires. all adding up to around 2500. to trade it, most likely i would get a stock tacoma and i would have spent money for nothing.
  5. May 8, 2009 at 4:20 AM
    Janster
    Jandy
    Lancaster, PA
    Did you save any of the original equipment that you took off the truck?
    You can swap the original equipment back in and keep all the modifications you've already done and put them into a new truck.
    I'd hate to say this but.... the amount of money you'd lose ($2500) by trading the truck will be far cheaper than the cost to swap an engine. When you add the cost of the engine, the time & labor, the extra parts, the problems you'll run into, etc.
  6. May 8, 2009 at 9:54 AM
    ryanf
    ryanf Well-Known Member
    NY
    06 AC 4X4 6cly/6spd TRD-OR
    Rain Visors,
    wow, take all your stereo gear out, that swap is not worth the effort.
    1st, if you're asking, im going to assume you're not mechanically inclined, not a dig, just meaning you will have to pay someone to do it.
    you will need to change the motor mounts, which requires cutting, and GOOD welding, then the tranny mounts, and cutting into the floor for shifters, new console, clutch mount, new belhousing, ECU swap, all the basics that go with the motor, lines, electrical, ect.
    Plus the cost of the new parts, taking them out of the other one....
    You will spend a fortune, and then if you ever try to sell, good luck trying to sell a VIN that is a 2.4 and you hacked it all up to swap...
    just sell it!!
  7. May 21, 2009 at 10:42 PM
    efranck2
    efranck2 The Eternal E
    St. George Utah
    2004 Tacoma Limited Doublecab 4x4 impulse red
    Brute Force Intake, Flowmaster Exhaust, 3 Inch Lift, Bilstein shocks, HiD Lights, Security System, Gray wire mod,
    just buy mine lol
  8. May 21, 2009 at 10:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you have done an engine swap before, its not that hard. Its time consuming, but easily doable.
