is there a fix for the loose wobbly hood?
Discussion in '1st Gen. Tacomas (1995-2004)' started by keakar, Oct 3, 2014.
  1. Oct 3, 2014 at 7:15 AM
    keakar
    keakar [OP] Well-Known Member
    karl
    louisiana
    im sick of the always loose wobbly hood issue
    anyone have a good hood support mod or thread or video showing how to better support this flimsy way it sits on the truck? I hate to see it fluttering as I go down the expressway like its not closed good
    wilcam47 and 1997tacomav6 like this.
  2. Oct 3, 2014 at 7:37 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    I can't tell you how much better I feel knowing that yours does that, too.
  3. Oct 3, 2014 at 7:46 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Haha mine too. Sometimes it is hard to pop the hood because of a lack of pressure too.
    Ideas?
  4. Oct 3, 2014 at 8:09 AM
    mtnkid85
    mtnkid85 Well-Known Member
    MT
    1999 TRD Taco
    35s, Locked, blown
    Turn the little round rubber bumpers up that are located under the hood in the front corners. They just twist up/down. They apply pressure to the hood while latched.
  5. Oct 3, 2014 at 8:10 AM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Mine are maxed out :rolleyes:
    Rachelsdaddy likes this.
  6. Oct 3, 2014 at 9:29 AM
    keakar
    karl
    louisiana
    mine are solid bumpers that don't adjust and my brothers (89) are the kind that adjusts but his are maxed out and his does the same.
    I was planning to put some of those stick on chair leg pads under the hood to apply pressure but I don't know how much gap I have and don't want to put undue stress in the wrong place
    figured someone knew of a hood spring mod or universal thingy to replace the stock bumpers with that will adjust better to hold it secure
  7. Oct 3, 2014 at 9:59 AM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    Rubber with age will shrink and being under compression over the years don't help much either. You may have to buy some new ones.
  8. Oct 3, 2014 at 5:05 PM
    keakar
    karl
    louisiana
    ya I was wondering about just that, I guess the new ones would likely be an updated version to the adjustable kind?
  9. Oct 3, 2014 at 7:53 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    Maybe you could try some thick foam weather stripping like the stuff that goes around house doors? Put a couple strips on the inside lip of fenders and another on the front clip? I am planning on doing his just to help prevent water dripping down into the engine bay when it rains, even though it's not much but still annoying if you keep your engine bay clean.
  10. Jun 12, 2018 at 10:34 PM
    tacoma08brandon87
    tacoma08brandon87 Well-Known Member
    brandon
    El Paso Texas
    TRD
    Has anybody done anything to fix it. Hate driving down the highway n hood going crazy. I mean it locks in well just loose
  11. Jun 13, 2018 at 9:31 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Wonder if you could put 2 holes in the back to put 2 more bumpers.
    Mine flutters worst at the passenger rear.
  12. Jun 13, 2018 at 9:35 AM
    mac84
    mac84 Well-Known Member
    Alabama
    2015 Tacoma TRD Sport 4WD MGM
  13. Jun 13, 2018 at 9:37 AM
    1997tacomav6
    Denver
    Mine does the same, I have thought about adding two more side bumpers towards the back side of the hood on the sides on the top fender, there are two towards the front
  14. Jun 13, 2018 at 10:14 AM
    tacoma08brandon87
    brandon
    El Paso Texas
    TRD
    What could it be so is it normal
  15. Jun 13, 2018 at 11:42 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    flimsy hinges.
  16. Jun 13, 2018 at 11:43 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    You could put some clay and measure it.
  17. Jun 13, 2018 at 11:50 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Duct tape.:D
    But yeah, it's probably those curly fry looking rubber bumpers at the corners.
  18. Jun 13, 2018 at 2:46 PM
    ironslippers
    ironslippers What? Me Worry?
    Colorado
    My hood stopped fluttering after removing the bug shield.
    wilcam47 likes this.
  19. Jun 13, 2018 at 5:48 PM
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    Mine does the same thing. I pulled over one time when. I first noticed it. Thought my good wasn't latched.
  20. Jul 25, 2018 at 11:41 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Notice the center of the hood flexing at the car wash and looked at the support ribs and most of those in the middle have the glue/caulk/whatever popped loose. Never seen this before. Anyone else have this?
