IS THERE A GASKET BETWEEN THE THERMOSTAT HOUSING AND ENGINE BLOCK???
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaPilot2004, Jan 26, 2011.
  1. Jan 26, 2011 at 11:04 AM
    TacomaPilot2004
    TacomaPilot2004 [OP] Active Member
    Miami, FL
    2004 Tacoma V6 4x4 Crewcab
    Hi everyone. I have a 2004 Tacoma V6 4x4 crewcab that I just purchased. It drove great for the first 1,500 miles or so and then it started to overheat one day. I checked it out, no leaks, fan is running, full of coolant, engine oil is good and full, so my first try at fixing this is to change out the thermostat.
    However, I looked at the FSM manual and it shows no gasket between the water inlet pipe and the engine block. After calling two toyota dealerships two separate times, and 2 local autoparts stores (Autozone and Pepboys), I've got all sorts of different responses telling me the there is a gasket, that there is not a gasket, etc. Pepboys even gave me a part number with a picture, but I believe it is for the upper outlet from the radiator.
    So my question is, Is there a gasket between the lower inlet (thermostat housing) and engineblock. Should I worry about it, or just use RTV? I don't normally do my own car work, but after buying this truck, I really want to learn to do everything myself and want to do it the right way.
    thanks!!
  2. Jan 26, 2011 at 11:06 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    it should be on the t-stat itself images_63ae723587a9b501c0637d7819ca3299954e6885.jpg
  3. Jan 26, 2011 at 11:07 AM
    TacomaPilot2004
    Miami, FL
    lol...I already bought the thermostat... maybe I should've actually looked at it.
    So it's already attached to it? I'm at work right now, but I'll check as soon as I get home. Thanks!!
  4. Jan 26, 2011 at 11:13 AM
    TacomaPilot2004
    Miami, FL
    Ok, so I just saw the picture you uploaded. When I purchased the t-stat at Autozone, they sold me exactly that. A t-stat, with a separate 0-ring/gasket (Sorry, not good at the terminology yet). And they also sold me that RTV silicone stuff. SHould I also use that? Or is that a bad idea?
  5. Jan 26, 2011 at 11:14 AM
    98tacoma27
    Ben
    Not Beech Creek
    No silicone is needed.
  6. Jan 26, 2011 at 11:19 AM
    TacomaPilot2004
    Miami, FL
    Just to confirm, are you saying that I DO NOT need silicone anywhere?
    Is the black circular gasket all it needs?
  7. Jan 26, 2011 at 11:23 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    DUDE , use the RVT silicone also
  8. Jan 26, 2011 at 11:26 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    if you're talking about the elbow that leads to the t stat then you do use form in place gasket material.
    http://www.4x4wire.com/toyota/maintenance/timing_belt/
  9. Jan 26, 2011 at 11:49 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, all you need is the o-ring that comes on the T-stat. YOU DO NOT NEED SILICONE OR RTV.
  10. Jan 26, 2011 at 11:50 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    x2
  11. Jan 26, 2011 at 11:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X3
  12. Jan 26, 2011 at 12:09 PM
    TacomaPilot2004
    Miami, FL
    Ok so I guess that's it! No silicone, only thermostat and black o-ring/gasket is the only thing I'm going to change. I hope this solves the overheat problem!
    Thank you so much to everyone!! I really appreciate everyone's help. I'll post how it goes after.
  13. Jan 26, 2011 at 12:10 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    sure you wanna use a autozone t-stat ......
  14. Jan 26, 2011 at 12:11 PM
    98tacoma27
    Ben
    Not Beech Creek
    You can test the old one also. It should be closed when you pull it out. Dip it in near boiling water quick and it should open.
  15. Jan 26, 2011 at 12:29 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Personally, I will always thin coat some RVT to a gasketed surface with the exception of a mated machined surface ..
  16. Jan 26, 2011 at 1:11 PM
    TacomaPilot2004
    Miami, FL
    I have one more concern. I absolutely cannot unscrew the dumb drain on the bottom of the radiator, so I was going to siphon out as much as I can through the radiator top. I've read that if you get coolant/antifreeze on the belts, you should change them, and it sounds like I'm going to get some on the belts...any advice?
    Does it really matter if the belts get a little wet with coolant/antifreeze? I suppose I can just quickly spray it down with water.
  17. Jan 26, 2011 at 1:17 PM
    98tacoma27
    Ben
    Not Beech Creek
    It will not hurt them.
  18. Jan 26, 2011 at 1:18 PM
    PHaslam
    PHaslam Member
    1998 Tacoma TRD 4X4
    3 inch lift
    If you want drain your rad and can't undo the drain plug just pull the bottom rad house off where it connects to the rad. Might as well by some rad flush and run that thru it while your hands are dirty
  19. Jan 26, 2011 at 1:56 PM
    HogTaco
    HogTaco Well-Known Member
    Northwest Arkansas
    2011 Access Cab 2.7 2WD AT
    Bed Mat, OEM Running Boards, Ultra-Gauge.
    I would get the radiator tested before you go to the trouble of replacing the tstat. It may be clogged, depending on if the previous owner put some of that "magic" radiator sealant crap in it. It might just be ready for replacement, too.
  20. Jan 26, 2011 at 2:20 PM
    TACO2003
    TACO2003 Well-Known Member
    Doug
    Fayetteville, North Carolina
    2003 SR5 TRD 4X4 Black Tacoma
    6" Fabtech Suspension lift. Headers with dual exhaust. Flowmaster muflers. Engine Computer chip. Tiregate with spare tire. Mickie's TTC Claws 315/75R/16 tires. Dick Cepec DC II wheels. Shrockwork front winch bumper. 8,000 Lb Warn Winch. Heavy duty leaf springs. K&N cool air intake. Sprayed bed liner. Bushwacker flare fenders. 1/2" Steel plated rear bumper.
    There is an easier test of the Tstat. When your truck engine is cool/cold. Open your radiator cap and start your truck. At the begining you should not see any flow through the cap openning. Once your Tstat gets to operating temp around 180 degrees (models vary in temp) it will open and you should see the water/glycol mix flowing in your radiator. The water pump will push the mix through your engine. If you see no flow then change out the Tstat.
    OG_Tacoma likes this.
