IS THERE A GASKET BETWEEN THE THERMOSTAT HOUSING AND ENGINE BLOCK???
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaPilot2004, Jan 26, 2011.
  1. Jan 26, 2011 at 2:25 PM
    HogTaco
    HogTaco Well-Known Member
    Northwest Arkansas
    2011 Access Cab 2.7 2WD AT
    Bed Mat, OEM Running Boards, Ultra-Gauge.
    If the radiator is bad, flow would be bad, too.
  2. Jan 26, 2011 at 3:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Some of the silicone sealants can react with the soft rubber gaskets that come on the T stat and eventually cause a leak. Its really not a good idea to use it, unless the manufacture requires it.
  3. Jan 26, 2011 at 3:34 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Your right Chris I shoulda been a little clearer, besides the "O" ring IS the gasket.....:)
  4. Jan 26, 2011 at 3:35 PM
    TACO2003
    TACO2003 Well-Known Member
    Doug
    Fayetteville, North Carolina
    2003 SR5 TRD 4X4 Black Tacoma
    6" Fabtech Suspension lift. Headers with dual exhaust. Flowmaster muflers. Engine Computer chip. Tiregate with spare tire. Mickie's TTC Claws 315/75R/16 tires. Dick Cepec DC II wheels. Shrockwork front winch bumper. 8,000 Lb Warn Winch. Heavy duty leaf springs. K&N cool air intake. Sprayed bed liner. Bushwacker flare fenders. 1/2" Steel plated rear bumper.
    True but, what would be the cheapest to fix? He could even pull the tstat and check for flow.
  5. Jan 27, 2011 at 6:08 AM
    TacomaPilot2004
    TacomaPilot2004 [OP] Active Member
    Miami, FL
    2004 Tacoma V6 4x4 Crewcab
    Hi everyone,
    When I got home last night, before actually changing out the t-stat, I decided to turn on the engine and try and see if it would overheat again.
    I ran the truck hard, accelerating fast, and even left it on idle for several minutes, and nothing. I can't get it to run hot anymore... While I'm a little happy that it's running fine now, I'm mostly worried that I can't trust my truck at the moment.
    Has anyone ever run into a problem where it overheats just one time? When the overheat happened, I was stuck in dead-stop traffic for about 10 minutes. As the needle was approaching the red, I pulled over and let it cool down. When I opened the hood, I realized the overflow tank cap was popped off (which might explain the radiator smell I'd been smelling for a few days). Can the cap being popped off be the cause of the overheat? Is that why it's running fine now???? Please help!!! Thanks!!
  6. Jan 27, 2011 at 6:36 AM
    TacomaPilot2004
    Miami, FL
    TACO2003,
    Thanks for that testing tip. I'd rather first do that than take everything apart for nothing.
    By the way, I tried to recreate the overheating condition last night and had no luck. The truck is running perfect and I can't think of what it could be. I can't get it to heat up again. I started a new post regarding a "one-time" overheat problem:
    http://www.tacomaworld.com/forum/1s...ted-only-one-time-what-could.html#post2655521
    THanks,
  7. Jan 27, 2011 at 8:26 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    x2:D
  8. Feb 1, 2011 at 6:22 AM
    TacomaPilot2004
    Miami, FL
    Thank you for everyone's input!!!
    I ended up removing the t-stat and throwing a new Toyota t-stat, which only took about an hour or so, but it still overheated a bit. After comparing the airflow from my truck to an older 1999 Tacoma that I have sitting, I noticed the incredible difference. Went over to the parts store, changed out the fan clutch, and my tank is back up and running incredibly AWESOME.
    Thank you to everyone!!! Appreciate everyone's help and input!
  9. Feb 1, 2011 at 6:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    So the fan clutch was bad also??
  10. Feb 1, 2011 at 6:07 PM
    TacomaPilot2004
    Miami, FL
    Ahh I'm starting to get discouraged here . I now changed out the t-stat and fan clutch, and while it did improve the airflow tremendously, it overheated again!!!!
    I have no idea what to do????
  11. Feb 2, 2011 at 6:03 AM
    TACO2003
    Doug
    One more cheap trick. Have you replaced the radiator cap? It works as a relief valve. If the pressure gets to high, it will open and allow the boiling mix to dump into your plastic reserve tank. If it's not working, pressure will build up and cause you to overheat. See the below link to help you understand the cooling system.
    http://www.familycar.com/classroom/coolingsystem.htm
  12. Feb 7, 2011 at 7:06 AM
    TacomaPilot2004
    Miami, FL
    Hi everyone,
    Thanks for the input. I just now fixed the problem..FINALLY!!!
    So aparently, the lower radiator hose was very old and weak, and it had been collapsing due to the suction pressure from the water pump. I NEVER noticed it before, but I also had no idea that that was something to check for. I changed it out and it's now running great. Not a single sign of overheating. In fact, the needle seems to be even lower than the middle now!! :)
    TACO2003...Thanks for that link!! Very helpful!!!
    OG_Tacoma likes this.
