Is there a low end mod for 3.5?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gorillam, Oct 6, 2016.
  1. Oct 6, 2016 at 5:55 PM
    gorillam
    gorillam [OP] Well-Known Member
    Is there anything that will improve the low end of my 3.5 in stick shift it's honestly horrible on logging roads, I have to rev the pis out of it. can never use second on any hill. So much boggy lag under 3K.
    Is there a reprogrammer/intake mod that will improve it? I just need some low end
  2. Oct 6, 2016 at 5:56 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Regear
    bradwhitenikki and Joe23 like this.
  3. Oct 6, 2016 at 5:57 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Press the ECT button
    Joe23 and Tcoma16 like this.
  4. Oct 6, 2016 at 5:57 PM
    jake72
    Jake
    N.E. PA
    If 4x4 use low range
    Joe23 likes this.
  5. Oct 6, 2016 at 5:57 PM
    gorillam
    I was actually thinking about this, mine ix 4x4 is it even possible or does tcase have to be regeared?
  6. Oct 6, 2016 at 5:59 PM
    gorillam
  7. Oct 6, 2016 at 6:00 PM
    gorillam
    6 speed manual, does nothing to answer my question.
    Does anyone else wan't to tell me mcdonalds has a special on tuesday?????
    Redferdaze likes this.
  8. Oct 6, 2016 at 6:01 PM
    gorillam
    Why do I even bother posting questions.... to reiterate I am looking for a "MOD" or "UPGRADE" or "REFLASH" to improve bottom end of ENGINE.
  9. Oct 6, 2016 at 6:03 PM
    jake72
    Jake
    N.E. PA
    Don't know what's up with the name calling, but low range will help with low end. Any dummy knows that though
    Joe23 likes this.
  10. Oct 6, 2016 at 6:04 PM
    gorillam
    Low range will help improve the low end power of my engine. Lol
  11. Oct 6, 2016 at 6:04 PM
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    I doubt anyone makes one yet but a heavier flywheel might help some. My dad has a 16 6 speed and he hates the lack of tourque compared to his 4.0 6 spd fj.
    gorillam[OP] likes this.
  12. Oct 6, 2016 at 6:05 PM
    gorillam
    Thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    You understand exactly what I am trying to ask for help with on the engine. Did him or any speed shop find a solution, it needs more bottom end and baaaadly.
  13. Oct 6, 2016 at 6:07 PM
    CJREX
    CJREX Well-Known Member
    Georgia
    Unfortunately, the 3.5 is thinly torqued at lower RPMs and has to be revved to get into the power band.
    The only thing that would significantly improve the lower power band is a supercharger.
    3.5 liters without forced induction is going to have to rev to move some air/create power.
    Regearing won't technically improve your power, it will get your engine into its power band quicker (more revs to turn the axles the same amount).
    Regearing is not a cheap endeavor. Figure on at least $1000 for gears and installation front and rear.
    A heavier flywheel won't add any power either.
    A flywheel stores energy and a heavier one will allow for easier clutch engagement without "slipping" it so much.
    It may help you get started more easily, but it won't really improve your performance.
  14. Oct 6, 2016 at 6:07 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    No problem. Ur issue now is finding one or getting one made or maybe even having it modified. I honetly just thought of this for the 3rd gen i gotta let him know about it.
  15. Oct 6, 2016 at 6:09 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Regear is your only option. Unless someone makes a supercharger or comes out with a turbo setup which I doubt that will probably be the only option ever. There won't be a programmer, the ECU software is complex enough with it running Otto to Atkinson. Toyota already used gear ratios to try and make up for the loss of power with the Atkinson cycle
  16. Oct 6, 2016 at 6:09 PM
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    I have to disagree with that. The heavier flywheel will increase the bottom end.
    Just like putting a flywheel weight on a dirt bike. Gives you more bottom end.
    And yea ull get more power with boost but thats not the only answer
  17. Oct 6, 2016 at 6:11 PM
    Aussiek2000
    2016 Offroad AC
    Atkinson is only used while cruising or light load. So that argument is irrelevant
    Herniator likes this.
  18. Oct 6, 2016 at 6:11 PM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Long tube headers help with low end torque but not enough to notice really. Plus I don't know of anyone making them yet and it would be tough to be emissions legal.
  19. Oct 6, 2016 at 6:13 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Like others have said, a taller gear will be the cheapest and. It's effective mod currently. Next would be a super charger.
  20. Oct 6, 2016 at 6:14 PM
    Persnickety
    Persnickety Well-Known Member
    2016 TRD Sport 4x4
