IS THERE A MAX. OFFSET A 2ND GEN CAN HANDLE????????
Discussion in 'Wheels & Tires' started by Detective_Dan, Jan 11, 2011.
  1. Jan 11, 2011 at 6:29 PM
    Detective_Dan
    Detective_Dan [OP] "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    anybody know? i know the recomended minimum for 285 tires is around -12 but what about the max? i found a badass wheel i want with a -38mm offset
    HELP PLEASE!!!!!!
  2. Jan 11, 2011 at 6:39 PM
    Detective_Dan
    Colorado Springs
  3. Jan 11, 2011 at 6:43 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Do not fear, I have arrived.
    the backspacing is a much more important than the offset alone. Backspacing is calculated using offset and rim width.
    The -12 offset is ideal for 285's only on a 9" wide rim. That's because -12mm offset on a 9" rim is 4.5" backspacing.
    So it's important to know the width of the rims you are looking at. My first instinct is that -38 offset with any rim width would be too little backspacing.
  4. Jan 11, 2011 at 6:49 PM
    KPT
    09 Prerunner
    Alright I just got the link to load on my blackberry. Looks like they are 10" wide. That's a reaaaaaly wide rim for running just 285's. It says they are 4" backspaced.
    So they will sit out 1.5" further than the 9", 4.5" bs rim I mentioned early (0.5" from the backspacing, 1" from the width).
    It's a tough call but they might sit out too far and cause some rubbing.
  5. Jan 11, 2011 at 6:52 PM
    Detective_Dan
    Colorado Springs
  6. Jan 11, 2011 at 6:55 PM
    KPT
    09 Prerunner
    Now we're talking, those are perfect.
    Only thing to double check is that someone on here is running those, because some aftermarket 16's rub the calipers.
  7. Jan 11, 2011 at 6:58 PM
    Detective_Dan
    Colorado Springs
    i know MikesDoubleCab had them, but hes a 1st gen so idk if it does me any good asking him, let me search again real quick just to double check....
  8. Jan 11, 2011 at 7:03 PM
    KPT
    09 Prerunner
    Yeah that won't do any good. 1st gens can fit 15's.
  9. Jan 11, 2011 at 7:06 PM
    Detective_Dan
    Colorado Springs
    ok apparently theres a caliper issue on the 2nd gens. if your truck came stock with 16's, they are supposed to fit. mine came with the 17's so there is a possible caliper issue, but those wheels dont come in a 17 that i can find. F**K MY LIFE!!!! im gonna google them lol
  10. Jan 11, 2011 at 7:08 PM
    KPT
    09 Prerunner
    No it's all to do with the rim. You have the same calipers as the trucks with 16's.
  11. Jan 11, 2011 at 7:15 PM
    Detective_Dan
    Colorado Springs
  12. Jan 11, 2011 at 7:17 PM
    KPT
    09 Prerunner
  13. Jan 11, 2011 at 7:18 PM
    Detective_Dan
    Colorado Springs
    you mean i would have to grind my caliper to make these fit??
  14. Jan 11, 2011 at 7:21 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    its barely any that you have to grind if you do.
  15. Jan 11, 2011 at 7:22 PM
    KPT
    09 Prerunner
    That would be the worst-case scenario.
    Don't get me wrong a LOT of people run aftermarket 16's on here, but there are some models of rims that hit the calipers. I just can't tell you for sure that they will fit with no issues.
  16. Jan 11, 2011 at 7:23 PM
    Detective_Dan
    Colorado Springs
    FML, is caliper grinding dangerous?
  17. Jan 11, 2011 at 7:29 PM
    KPT
    09 Prerunner
    Never done it. I assume you just grab an angle grinder and have at it.
  18. Jan 11, 2011 at 7:31 PM
    Detective_Dan
    Colorado Springs
    a spacer would solve this issue wouldnt it? im not thrilled about spacers, just a thought....
  19. Jan 11, 2011 at 7:34 PM
    KPT
    09 Prerunner
    Depends on how much of the rim was rubbing. I'll let someone else who has actually done it comment.
  20. Jan 12, 2011 at 2:30 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    If you look at your front brakes. They are farely big. When I put my 16's on they barely fit over the caliper. I don't think it's a spacing issue as much as the wheel opening isn't big enough to clear the front caliper.
    I have run wheels with 5.71" backspace with 285's on stock suspension with no rubbing. :)
