Is there a method to help determine what size wheel and tire will fit?
Discussion in 'Wheels & Tires' started by Bryan139, Apr 29, 2011.
  1. Apr 29, 2011 at 9:40 AM
    Bryan139
    Bryan139 [OP] I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    The the faq links give the largest tire for stock suspension. And there are dozens of "will this fit" threads to sort thru. Is there a general method you can use to get an idea of what tire size you can fit based off the size of the lift besides searching tons of threads or relying on expierence (some of us don't have any)? Like for example, for every 1" you lift you truck you can add about 10% to the overall hight of the stock tire? Sort of like a tire size rule of thumb? Or does it just come down to search, search, and search some more?
  2. Apr 29, 2011 at 9:41 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I personally havent heard of any "rule of thumb" rule.:cool:
  3. Apr 29, 2011 at 9:42 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    it's not really an end all be all kinda thing. you can fit 285s on a 3" w/ tirmming or you can fit 315s on a 3" w/ a lot of trimming and cutting.
  4. Apr 29, 2011 at 9:44 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    The biggest tire you can fit on a stock truck is 265x75x16 without cutting. Anything bigger and you will have to do some trimming. Every tire is different so you start with a ballpark number and trim as needed. These wheel wells were designed for only a few tire sizes so doing anything but those will require modification.
  5. Apr 29, 2011 at 9:45 AM
    JLee
    Jerry
    Bay Area NorCal
    Damit whippersnapper02 you beat me to it :thumbsup:
  6. Apr 29, 2011 at 9:49 AM
    Bryan139
    NJ
    '09 Sport
    Yeah, I wasn't expecting anything written in stone. I picked up on the chalk method browsing thru threads the other day and was wondering if there were any other "methods" that applied to tires and wheels.
  7. Apr 29, 2011 at 9:51 AM
    JLee
    Jerry
    Bay Area NorCal
    My method is put on the wheel and tire you like and cut until it stops rubbing :D
  8. Apr 30, 2011 at 7:06 PM
    DevL
    DevL Well-Known Member
    Other than the alignment there is no differnce in 1, 2 or 3" of lift vs stock. Its the same arms stuffing the tires in the same fender... once you stuff the wheel its the same as stock.
