Is there a mod to make the stupid "fasten your seatbelt" light quit blinking?
Discussion in '1st Gen. Tacomas (1995-2004)' started by veg hed, Aug 8, 2010.
  1. Aug 8, 2010 at 3:24 PM
    veg hed
    veg hed [OP] Well-Known Member
    Utah
    04 Toyota TRD SR5 V6 Access Cab
    Bilstein 5100s, Toytec 620 springs, OME Dakar Leafs, ARB Bumper, Warn 8000 Winch, Grey Wire Mod.
    So I'm a law abiding citizen and all but seriously, I hate that stupid blinking light.
  2. Aug 8, 2010 at 3:25 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Take the bulb out.
  3. Aug 8, 2010 at 3:27 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Fasten your seat belt, light stops blinking :cool:
  4. Aug 8, 2010 at 3:29 PM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    x2
  5. Aug 8, 2010 at 3:30 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    piece of electrical tape over the light :), at least theres no annoying ding ding noise to listen to
  6. Aug 8, 2010 at 3:31 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    x3
  7. Aug 8, 2010 at 3:34 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    x4
  8. Aug 8, 2010 at 3:35 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    x100
  9. Aug 8, 2010 at 3:35 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Unplug the electrical connector at the base of the seat belt buckle. On my 04 this worked fine without affecting the airbag. On a second gen, not sure what would happen.
  10. Aug 8, 2010 at 3:40 PM
    veg hed
    Utah
    Yeah, I figured I get some of this but seriously. I live in an area that is off the beaten path and I don't always feel like dealing with a seatbelt, especially for a short drive where I'm only going 5-10 mph. Trust me, I wear my belt 99% of the time but just wondering if there was a quick wire to cut or something instead of taking the dash apart to get to the bulb. Seems like there is a mod for everything else.
  11. Aug 8, 2010 at 3:42 PM
    veg hed
    Utah
    Ill give it a try....Thank you!
  12. Aug 8, 2010 at 6:09 PM
    kg4ghn
    kg4ghn Well-Known Member
    GA
    13 PreRunner TRD Sport
    Take the bulb out. Takes all of 30 minutes to do and you might as well change your dash light color while your in there.
  13. Aug 9, 2010 at 12:17 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Don't even waste your time with the bulb.
    Agreed, takes less than two minutes to unplug the connector under the seat. One of the fisrt things I do to every car I've owned. Have a feeling it won't work on my next one though.
  14. Aug 9, 2010 at 12:22 AM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Black electrical tape over the light. Problem solved
  15. Aug 9, 2010 at 12:50 AM
    veg hed
    Utah
    Yeah, I unplugged the little 2 prong connector underneath the drivers seat and the little annoying light quit blinking at me.
    I'm not anti-seatbelt I just hate the idea of my vehicle trying to tell me what to do. One of our work trucks is a domestic full size truck and it is constantly flashing stuff on the odometer display area like "time to change the oil, service engine soon" and the omni-present "washer fluid low." Not sure if 2nd gens do this but I'm sure glad my 1st doesn't have this option.
    Sorry, I went off on a little rant there.
  16. Aug 9, 2010 at 6:40 AM
    Barnone
    Barnone Guest
    x1000
    You flip and roll down the mountain at 5 mph on your short ride and you gonna wish the seat belt was fastened.
