Is there a normal disposable oil filter for these trucks?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jboudreaux1965, Jan 19, 2024.
  1. Jan 19, 2024 at 1:47 PM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    i just realized what a PITA changing the oil is on these. Is there any normal filters we can use instead of having to disassemble the filter?
  2. Jan 19, 2024 at 1:50 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
  3. Jan 19, 2024 at 1:59 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Baxter makes an adapter, it’s like $250
    I had one, sold it
    My dealer stated they would not warranty any engine issue related to oil system with that installed. Wasn’t worth it to me.
    The factory filter is a breeze with the right tools. Less of a mess than the spin on you want to use
    69 Jim likes this.
  4. Jan 19, 2024 at 2:02 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    yeah, I'd just get a proper canister tool and get used to it. It's actually a good setup and easy,, just different for some, but nothing we can't learn in one pass.
    69 Jim, Kolohe07 and Irons like this.
  5. Jan 19, 2024 at 2:07 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    any idea what part this is?
    in the pic
  6. Jan 19, 2024 at 2:11 PM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    jboudreaux1965[OP] likes this.
  7. Jan 19, 2024 at 2:17 PM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    The baxter one looks neat, but $250 is a lot of money for something that will save me minutes of work a couple times a year. I'd rather spend $250 on an amazing bottle of Scotch to crack open every time I change my oil. What I really miss is my 2nd gen filter on the topside of the engine bay.
    Just get an aluminum housing for the factory filter and keep the plastic one as a spare.
    VirusCage, Jesse H, auskip07 and 8 others like this.
  8. Jan 19, 2024 at 2:34 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
  9. Jan 19, 2024 at 2:48 PM
    BabyBilly
    Billy
    2020 TRD
  10. Jan 19, 2024 at 2:54 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
  11. Jan 19, 2024 at 2:58 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    :rofl:
    :fistbump:
    :thumbsup:
    Delta09 and soundman98 like this.
  12. Jan 19, 2024 at 3:56 PM
    chasecmc
    chasecmc Well-Known Member
    Chase
    2017 DCSB TRD OR
    GFC
    It’s highly recommended to stick with the OEM filter setup. If you drain it prior to removing the filter housing it shouldn’t be messy.
  13. Jan 19, 2024 at 4:29 PM
    jersey jim
    jersey jim Well-Known Member
    Jim
    2018 Cement DCSB TRD Sport 4x4 6MT
    I honestly have no issue with the oil filter, maybe because it reminds me of the similar setup on the old Japanese motorcycles I had.
    Use the right tools and follow the procedure, it's really not a bad setup. Use a Toyota filter, they're cheap enough.
    The biggest pain in the rear has been the splash shield bolts, I'm pretty sure the damn thing hadn't been removed on a number of the Toyota provided oil changes, bolts were rusted and one was seized, what a pain. Jerks. Liberal application of anti-seize is key. This is why I do it myself now.
    And the engine is so far off the damn ground compared to my cars, it blows the oil away from the drain pan if it's breezy, and it always seems to be breezy as soon as the drain plug comes out. I think I want to get a Fumoto just so I can stick a hose on it and run it right into the drain pan.
    Williston, Gatafly and faawrenchbndr like this.
  14. Jan 19, 2024 at 4:38 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i think you're doing it wrong.
    oem/stock, i can change my filter with a high dollar suit on without issue. with the fumoto valve, i can do the same thing with my oil pan as well.
    i use this kit
    https://www.amazon.com/Motivx-Tools-Filter-Wrench-Advanced/dp/B0791MWXDC
    the tube and thread on insert is used to remove oil from the filter(after the oil is drained out of the oil pan), then the wrench is used to remove the housing, and later used to reinstall the housing.
    following that method, and using the drain tube, it's extremely easy to drain the entire remnants of oil in the filter straight into the catch pan, preventing any splash. by the time it comes to removing the canister, all that must be removed is an oil-saturated filter. cleanup is easily done with a few paper towels.
  15. Jan 19, 2024 at 6:00 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Re: "breezy..." Yes! this happens to me about 50% of the time: pan (big one) drain hole directly under the flow coming out and it seems all fine until near the end when you're in the final "thread" flow phase.... then here comes the breeze and winds and it blows the oil all over the place outside of the pan and makes a mess.
    OH: And if you put a big cardboard piece under the pan (pizza box) you'll just get stronger winds: :annoyed: ....don't do it. I swear if I were to put a layer of speedy-dry all around the pan, it would trigger thunderstorms with even higher wind gusts. Being up on ramps in the front makes it even worse.
  16. Jan 19, 2024 at 6:38 PM
    jersey jim
    Jim
    I used a box from a 50" TV last time, it still managed to blow onto the driveway. I hate oil spots on the driveway, but an application of kitty litter and then scrubbing with some Simple Green mitigated the disaster :bananadance:.
    69 Jim and Williston[QUOTED] like this.
  17. Jan 19, 2024 at 6:38 PM
    kaljam
    kaljam Well-Known Member
    Bill
    New Hampshire
    2023 TRD Sport wind chill pearl
    I just purchased the Baxter adapter from Northridge 4X4 for $218 and some change free shipped.
  18. Jan 19, 2024 at 6:45 PM
    TRD_dee151
    TRD_dee151 Well-Known Member
    Oregon
    2023 TACOMA TRD OFF ROAD V6 Celestial Silver
    TRD Pro Grille 5% Window Tint WeatherTech Side Window Deflectors Cali Raised Catalytic Converter Shield Leather Seat Covers JDMCAR Center Console Organizer JDMCAR Glove Box Organizer High Flying smoke Sequential Turn Signal Tactical Sun Visor Molle Panel BumperShellz Armored Coated OEM TRD PRO Skid Plate Alpharex LUXX-Series LED Tail Lights Alpha-Black 255/70/17 Falken AT/4 all stock no lift. 17" Method 305nv Double Black with 0 offset Diamondback Switchback Baja Designs Squadron-R Fog Light
    I still need to order this, But i still have 1yr left of Toyota care......
    Plus I am able to choose WHO I would like to pick to do my oil change at Toyota, Thats cause I now the young guy, plus he goes to my gym and we both follow each other on I.G so I know he will always do it right to my truck....
  19. Jan 19, 2024 at 6:47 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I might find the filter to be different, but pain in the ass? No. It took one change to get the hang of it. And now, believe it or not, I actually like it better than the spin-on.
    The other car is a spin on. It's the lack of hand space, the inability to get a legit wrench up there to loosen it... Now that's a pain in the ass. At least with ours there are facets for the tool to grip onto. I don't need to reach. The socket extension does the reaching for me.
    Shits easy, yo.
    soundman98, Chew and Sandthemall like this.
  20. Jan 19, 2024 at 6:48 PM
    Sandthemall
    Sandthemall Well-Known Member
    Sandamal
    2023 TRD OR MT
    Williston and Chew like this.
