Is there a reason modern trucks don't come with fully sealed frames to prevent rust?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crackedmirror, May 7, 2021.
  1. May 8, 2021 at 11:01 AM
    #61
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    why would you go to a heavier frame if you aren't prepared to put a V8 or a V6 in it. Makes no sense.
    shakerhood likes this.
  2. May 8, 2021 at 11:02 AM
    #62
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think that is already confirmed as they will be sharing the platform across many vehicles to save money, guessing the 4th Gen will be a 4 cylinder turbo.
  3. May 8, 2021 at 11:04 AM
    #63
    shakerhood
    Southern Ohio
    The Frontier shares the Titan Frame so it seems like a pretty common practice.
    Junkhead and tacoman45 like this.
  4. May 8, 2021 at 11:04 AM
    #64
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    I wonder if they’re going to turbo charge the 2TR or some derivative of it for the 4G Tacoma. Add in hybrid tech for on-demand, instantaneous electric torque and it might kick ass.
    Junkhead and shakerhood like this.
  5. May 8, 2021 at 11:05 AM
    #65
    RatDaddy
    Roy
    None
    yeah, but the V6 in the frontier has more hp and torque than the Taco. And the Frontier likely has a lot less sound deadening if the pro4x I drove is any indication. The frontier feels like a clunky rattle trap inside. No comparison to the Taco.
    shakerhood[QUOTED] likes this.
  6. May 8, 2021 at 11:08 AM
    #66
    shakerhood
    Southern Ohio
    I think the Frontier 4.0 made less HP but more torque than our trucks, but yeah they are quite primitive in comparison.
    Junkhead and RatDaddy[QUOTED] like this.
  7. May 8, 2021 at 11:10 AM
    #67
    RatDaddy
    Roy
    None
    maybe better gearing as well. The one I drove could spin the tires off the line. The only way you are doing that in a Taco is if it's a manual and you dump the clutch.
    Lets hope the final choice for the new drivetrain isn't worse.
  8. May 8, 2021 at 12:07 PM
    #68
    Apollo14
    Apollo14 EEF Brand Ambassador
    Jonathan
    Vail, CO
    2018 Cement Taco TRDOR DCSB
    still a FR mount and not a transverse mount like FWD cars
  9. May 8, 2021 at 12:26 PM
    #69
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
  10. May 8, 2021 at 12:28 PM
    #70
    shakerhood
    Southern Ohio
    I don't think that is correct, l could swear l remember seeing the Ridgeline engine sit side to side, however l might be confusing it with something else.
  11. May 8, 2021 at 12:33 PM
    #71
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Well you are wrong. I live in Buffalo NY and the "sandwiched" frames rust out bad here, Tacomas don't even make it 10 years untreated.
    A 3/16" (instead of 1/8" sandwiched) frame would be the best option for corrosion, and would barely increase weight of the frame.
    It's not just the salty roads, its the condensation from the wet environment.
    I have PTSD from precipitation lol.
    Here's poof, this is what happens, this frame was replaced by Toyota and was 7 years old at time of video (1G Tundra, same design as Tacoma 2nd/3rd)
    https://youtu.be/QHVfj1d0dIQ
  12. May 8, 2021 at 12:34 PM
    #72
    shakerhood
    Southern Ohio
  13. May 8, 2021 at 12:57 PM
    #73
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    From what i watched i wouldn't do what the video recommended mixing different products over each other. Its not likely to dry getting easily washed away. You want to encapsulate rust when trying to stop it.
  14. May 8, 2021 at 2:56 PM
    #74
    Apollo14
    Jonathan
    Vail, CO
    a transverse mount is side to side. It’s a FWD vehicle with an AWD option that they pretend is 4WD. The GR motor the other person was referring to is a transverse mount in a Camry but a front to rear mount in a Tacoma. The Tacoma is RWD with 4WD option.
  15. May 8, 2021 at 3:41 PM
    #75
    shakerhood
    Southern Ohio
    Right l think l misunderstood as l thought you were saying the Ridgeline was a Front to Rear Configuration
  16. May 8, 2021 at 3:55 PM
    #76
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    The 5 luggers weren't boxed.
  17. May 9, 2021 at 6:03 AM
    #77
    ARCHIVE
    Eric
    You're apparently the one with a gigantic brain (your words). To think frame flex makes it better in "every single metric" shows your lack of understanding.
    I'm not even arguing against C-channel, I am arguing against excessive frame flex, and it's negative effects on ride and handling and chassis composure at speed.
    Guess you'll have to pass on the next Tundra and Tacoma, boxed frames all around brain
  18. May 9, 2021 at 7:05 AM
    #78
    Stocklocker
    17TRDORDCSBAT
    You need a huge fuggin’ brain to understand sarcasm.
    Halibut likes this.
  19. May 9, 2021 at 7:33 AM
    #79
    zoo truck
    None
    I never saw a toyota yet owned, and driven a normal amount in the northeast that didn't have some good amount of rust when not treated....even after 3-4 years.
    JdevTac[QUOTED] likes this.
  20. May 9, 2021 at 8:08 AM
    #80
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    A short answer to the OP's question.
    No need for fully boxed frame.
    Reason: Materials, design and load analysis have advanced to remove weight helping vehicles meet the EPA Fleet Fuel Efficiency mandates from the Federal Government while meeting the Crash Worthiness Requirements.
    These mandates have led to extensive use of aluminum and plastics to reduce weight. Structure based on analysis of impact loads have led to better crush zones increasing the surviveability of frontal impacts.
    Complain and grump all you want. Vehicle design is heavily mandated by Govt for fuel efficiency and surviveability.
    Rust is a force of nature and it will happen. Deloren tried a Stainless Steel body.....although they plopped it on Fiat running gear. It wasn't a big seller.
