Is there a size limit to the "Tire change calibration"
Discussion in '3rd Gen. Tacomas (2016-2023)' started by harrytasker, Jan 1, 2023.
  1. Jan 2, 2023 at 8:41 AM
    MattG88
    MattG88 Well-Known Member
    matthew
    AZ
    2021 Tacoma TRD
    because it is cheaper to have 1 tpms antenna and use wheel speed and steering angle to localize the sensors
    hiPSI likes this.
  2. Jan 2, 2023 at 8:45 AM
    harrytasker
    harrytasker [OP] Well-Known Member
    Location doesn't work with one point of reference. Do you have factory nav?
  3. Jan 2, 2023 at 8:48 AM
    MattG88
    matthew
    AZ
    2021 Tacoma TRD
    the tpms has nothing to do with the nav, the tpms system uses the wheel speed sensor at each wheel and the steering angle to tell the system where the tire is located on the vehicle because the inside tires turn slower when making a turn
    hiPSI likes this.
  4. Jan 2, 2023 at 8:55 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    You and I are talking two different things, my fault, sorry.
    I thought you were talking about the underdash tpms button. But you're talking about a menu option in Nav.
    That option only calibrates Nav. (The nav computer does use wheel speed for some things, like calculating mileage and whatnot). It does not calibrate the speedo. Admittedly this next part is speculation, but allowing and encouraging the speedometer to be tampered with by the end user would make open season for massive lawsuits. I can't imagine the Toyota legal team being that dumb.
  5. Jan 2, 2023 at 8:59 AM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I thought about ‘how could this work’ and I suppose it’s possible there is some witchcraft black-magic in the Nav head unit that checks wheel speed against gps after selecting that option, and makes adjustments. Otherwise, how would it know what size or adjustment to make? But I’m still going with ‘it’s in the rounding error’.
  6. Jan 2, 2023 at 9:08 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    SAE specs give a "range" of error on speedometers of +- 2% or so.
    The reality is your speedometer is never really accurate. Your tires have different diameters based on temperature and air pressure. Your tires have a different diameter based on wear. And your tires, technically are never really rolling at the exact same rpm because of the variables listed above plus the inside or outside turning radius.
    So, the only true way to get an actual accurate speed the only way is thru gps comparing relative speed.
    Don't know what you guys are adjusting but it is not the speedometer and odometer. That is illegal.
    MattG88 likes this.
  7. Jan 2, 2023 at 9:13 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    This has been common amongst most MFG's for ever. It has been documented in many magazine car test articles. Is it because of MPG reporting?
  8. Jan 2, 2023 at 10:15 AM
    RushT
    North Texas
    If the odometer were off too, then one could argue it would clock more miles than reality and burn through mileage warranty faster. Speculation only. :)
  9. Jan 2, 2023 at 10:15 AM
    harrytasker
    Let me rephrase the question and request people only respond if they actually have done this.
    Has anyone WITH larger tires, ideally 33'+ AND factory navigation seen the tire change setting in the navigation correct the digital speedometer readout in the dash?
  10. Jan 2, 2023 at 10:20 AM
    harrytasker
    It wouldn't be black magic. If speed is registered at the wheels then the sensor counts the rotations and when the rotation hits a set number, let's say 60,000 then it knows the truck has done one mile. If Toyota programmed the navigation to have the nav report the time it took to drive one mile and recount the number of rotations then the original count of 60,000 could be reduced to 50,000 with larger tires. Now the truck is just counting the number of wheel rotations to determine if it hit one mile.
    RushT[QUOTED] likes this.
  11. Jan 2, 2023 at 10:25 AM
    RushT
    North Texas
    Pretty straight forward, ‘witchcraft’ is my lingo for all things blackbox. Lol.
  12. Jan 24, 2023 at 12:37 PM
    Potamus
    Potamus Well-Known Member
    Keith
    Oregon
    2022 Limited Blue Crush Metalic
    2.75 lift on 33s
    It does nothing. I tried the calibrate from nav settings with 33s. After a couple weeks it is still off. In the owners manual it states that the calibration in the nav is to fine tune exact location on the map.
    It has nothing to do with the instrument cluster.
    beergeek, TacoGranny and musicisevil like this.
  13. Jan 24, 2023 at 1:21 PM
    StandardTaco
    StandardTaco Well-Known Member
    Nebraska
    2020 MGM TRD-OR 6MT
    I still have stock tires so I haven't tried. But assuming it does affect the digital speedometer while not affecting the analog dial, do you see a difference in the reported speed between the two? I think that would answer your question.
  14. Jan 24, 2023 at 1:22 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    It doen't fix the speedometer!
    musicisevil and RushT like this.
