Is there a spacer that goes on top of the strut assembly???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by matt45648, Apr 13, 2009.
  1. Apr 13, 2009 at 6:55 PM
    matt45648
    matt45648 [OP] Well-Known Member
    Like on top of the entire assembly, just bolt on. I added aal and front 5100' set on 2.5 and the front is too low.
  2. Apr 13, 2009 at 6:55 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yes there are. Check out Toytec....
  3. Apr 13, 2009 at 6:55 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    How much more lift are you after?
  4. Apr 13, 2009 at 7:00 PM
    matt45648
    Maybe an inch..
  5. Apr 13, 2009 at 7:01 PM
    DanGer
    I would look at the trim packers, or lift enhancers at Toytech.
  6. Apr 13, 2009 at 7:02 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    would be an option.
  7. Apr 13, 2009 at 7:02 PM
    DanGer
  8. Apr 13, 2009 at 7:02 PM
    DanGer
    Damn you brunes
  9. Apr 13, 2009 at 7:03 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You made the link look good tho...I do have some pretty pungent Web-Fu right now tho...=)
  10. Apr 13, 2009 at 7:04 PM
    DanGer
    here as well
  11. Apr 13, 2009 at 7:06 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Check with Fat Bob's Garage online.
  12. Apr 13, 2009 at 7:06 PM
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    Damn yall are sharp with this stuff!
  13. Apr 13, 2009 at 7:07 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    It's fun...Gives me something to do when I should be studying or working...
  14. Apr 13, 2009 at 7:11 PM
    DanGer
    x2 btw i cant rep you any more for beating me haha
  15. Apr 13, 2009 at 7:12 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I've had that problem before too....It will pass!!
  16. Apr 13, 2009 at 7:13 PM
    DanGer
    To the OP, or you can drop down the billies a little and by my 2.25" spacers for sale :D
  17. Apr 13, 2009 at 7:33 PM
    matt45648
    Do the ones from wheelers come with extended studs???
  18. Apr 13, 2009 at 7:34 PM
    DanGer
    05-Current Tacoma 1.25" Lift Front Coil Spacer Kit: 39.95 [​IMG] Click for a picture. This kit mounts on top of the upper strut coil support plate and doesn't affect the actual spring rate. That means the ride firmness will feel similar to stock after installation of this kit. Comes with necessary longer stud kit.
  19. Apr 13, 2009 at 8:00 PM
    matt45648
    Is it possible to get the original studs out without compressing the spring?
  20. Apr 13, 2009 at 8:01 PM
    DanGer
    I believe so as long as you leave the middle one in
