Is There a Strut Bar for the Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dpak, Jul 29, 2010.
  1. Jul 29, 2010 at 4:53 PM
    dpak
    dpak [OP] Well-Known Member
    Richmond, VA
    09 4x4 TRD Offroad DCSB
    Toytec/Eibach coils w/ 5100's set at 0, Toytec 2.0 Aluma Rear Shocks, Toytec Boss Leaf Springs, TRD Catback Exhaust, SCS F-5 Matte Gray Wheels, Elusive Elements Mesh Grill
    Hello - I just purchased a '07 Double Cab/Short Bed, and was curious if there is a strut bar for the Tacoma? Before getting the Tacoma, I drove a a '06 Civic Si and loved the way it handled. Now, I'm not trying to speed in and out of turns or curves, but just trying to improve the handling.
    I tried searching for this topic but no success in finding results.
  2. Jul 29, 2010 at 4:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    not too sure, but they may have made one for the x-runners.
  3. Jul 29, 2010 at 5:04 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Considering the Tacoma utilizes a frame on body design VS the Civic's uni-body design, I'm pretty sure the answer is no, although I cannot say that with complete certainty. I cant see any real benefit to having a strut bar on the Tacoma since the strut essentially mounts directly to the chassis causing very little, if any deviation from one side to the other while cornering.
    Too Stroked likes this.
  4. Jul 29, 2010 at 5:05 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    they have rear sway bars for the x-runners im pretty sure. not sure if they'd work on anything else.
  5. Jul 29, 2010 at 5:24 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    They Tacoma does not use a real strut. It is a coil-over shock assembly. The front suspension uses a Short - Long arm suspension. The control arms are where all the forces are applied, and transfered to the frame. A Civc uses a Macphereson Strut. There is only one, lower, control arm. The upper part of the knuckle is attached to the strut and the top of the strut then is bolted to a bucket in the frame. Since the Strut is the second connecting point for the knuckle, it takes a lot of the road force, which then translates to the frame and ends up with flex. That is what the strut bar is for, to help prevent any flex at that point. Not sure if I explained this very well, but hope it helps.
  6. Mar 4, 2019 at 12:56 PM
    Tac2277
    Tac2277 Active Member
    Jack
    None
    Is there a cross over strut bar for 2016 Taco?
  7. Mar 4, 2019 at 1:10 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Ummmmm, ya.....
  8. Mar 4, 2019 at 1:11 PM
    dipstiktaco
    dipstiktaco Well-Known Member
    canada
    2006 TRD off road access cab auto URD supercharged
  9. Mar 4, 2019 at 1:14 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    See reply #5.
  10. Mar 4, 2019 at 2:16 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Sure you can make one. Start at the top of the coil over, get a torch and burn a hole through the engine block and feed the bar through and attatch it to the other side
