is there a such thing as a good failure?
Discussion in 'Lighting' started by mr smitty, Apr 24, 2010.
  1. Apr 24, 2010 at 10:57 PM
    mr smitty
    mr smitty [OP] Well-Known Member
    Tennessee
    09 prerunner sport
    Westin Chrome running boards Rough Country 3" lift 17x9 motometal 951 chrome mickey thompson baja atz 285/70 17
    I did the foglight mod on my truck about 2 weeks ago from some toyota nation instructions. It said to cut a red and black striped wire and splice it to a light green wire leading to the light relay. This caused my truck to end up break down 2 days after I completed the mod. Inspection showed the battery was drained so I assumed the alternator or something drained the battery. Once I got home I tested the engine and found that the alternator was not running while on the mod. I immediatley changed everything back and im running fine now
    Im 16 years old and all this taucght me a ton about the truck could this bad mod be a success in a way?
  2. Apr 24, 2010 at 11:34 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    Tools/items needed:
    • wire stripper
    • 1 quick splice
    • 1 female blade connector
    • 6" of wire
    • drill/bit same diameter as wire
    • shrink tube/electrical tape to reinforce crimp connection (optional)
    1. Locate the green wire on the plug in the pic
    2. splice into it
    3. run the wire to the fog light relay through a hole to keep it low and not hit the cover
    4. crimp on the female blade connector onto the wire
    5. pull the fog relay and bend the terminal in the pic to the side
    6. put the female blade connector onto the bent terminal on the fog relay
    7. replace fog relay
  3. Apr 24, 2010 at 11:53 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
  4. Apr 25, 2010 at 12:52 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Obviously you did not do it right.
  5. Apr 25, 2010 at 6:48 AM
    mr smitty
    Tennessee
    09 prerunner sport
    I floowed the exact instructions
    Thats not what went wrong
  6. Apr 25, 2010 at 6:55 AM
    Brunes
    Brunes abides.
    Rotorhead
    Sadly- I have to agree with Viet. Something didn't get done right....cause there is no way that someone would leave incorrect instructions for a mod posted in a "How-to" thread.
    Give the alternative method posted up above a try.
    And I would say it's a good learning experience-At least you see that you can return it to how it was if it doesn't work out right. Good luck!!
  7. Apr 25, 2010 at 7:06 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    Sold my truck Jan '13... Still hang around.
    To answer the question in your header... I believe there is. You didn't do permanent damage to your truck, you didn't hurt yourself or anybody else.. If you learned something from this mistake then I'd say it was a 'good failure.'
    I agree with Viet and Brunes about following the directions in the original thread, though. If the instructions were flawed, then the thread where you got them would be full of "this mod killed my truck" posts. I've screwed up on the directions of plenty of mods when I tried the first time. Don't be offended by somebody pointing it out. It happens.
    At least you didn't do this.
  8. Apr 26, 2010 at 5:56 AM
    mr smitty
    Tennessee
    09 prerunner sport
    I did the suggested mod and it works now thanks for the help
