Is there a tires size guide for lifted trucks?
Discussion in 'Wheels & Tires' started by packfan88, Jul 20, 2011.
  1. Jul 20, 2011 at 7:13 PM
    packfan88
    packfan88 [OP] Very Nice !
    Acworth, GA
    Billy Lift, Cooper STT Pro, Westin Step bars, tinted, rain gaurds, EBC rotors hawk pads
    I am awaiting delivery of my bilstein 5100s, coils and aal. Since im not 100% sure what kind of lift it will end up being I cant order tires and/or wheels. From what Ive learned, the front be adjusted a little bit higher and lower. the rear is a 2" aal.
    So is there a thread that im just not seeing that points out the different size tires you can fit under the truck with/with out cutting? Maybe a sticky like
    If you se the front at .85, you can safely fit a 285/blah/blah/blah
    or
    If you set the front at the 1.5", you can safely fit 315/xxxx/xx, but if you do some cutting you can fit 345/xx/xxx
    I have seen a lot of threads were people ask what can fit. Ive seen the thread with the sizes that fit on a factory truck with no lift. Nothing with the lifts. Seeing as how its pretty standard people are goign to use one of 2-3 lifts, maybe those with the knowledge can inform us retards what will fit.
    I am clueless on lifts and all things related to this Tacoma....i was a fast car guy not a truck guy. so im just trying gather knowledge.
  2. Jul 20, 2011 at 8:26 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
  3. Jul 21, 2011 at 5:42 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    0-1.75" - 265/75/16
    2.5+ 285/75/16, with properly backspaced wheels and trimming.
  4. Jul 10, 2014 at 4:54 PM
    thereverend
    thereverend rev
    Adam
    B'ham AL
    '14 DCSB TRD Sport 6spd SC
    TRD SC, URD 1 size smaller SC drive pulley, Volant CAI w scoop, TacoTunes full kit, MagnaFlow muffler for flow but ran out rear to kill the drone.
    What's the recommended BS and how much trimming?
    I have a 2014 DC TRD Sport and (not installed) 2" spacers with a 1-1.5" aal. I would like to run 285/75r16. is this possible? If not what can I run?
    Many thanks.
  5. Jul 10, 2014 at 6:34 PM
    SuperDutyDave
    SuperDutyDave Active Member
    Dave
    People's Republic of VT
    ToyTec Boss Syspsension 3"
    I'm told you'll need a 3" full lift with new UCA's to clear 285's assuming you have a wheel 8" with 4.5" BS and 0 offset Even then no flaps and some minor plastic trim.
    Some 285/75-16 run over 33" and some way under. The Nittos I just ordered are 32.65" some hoping they fit ok
  6. Jul 10, 2014 at 6:37 PM
    Annolino122
    Annolino122 Well-Known Member
    Evansville
    2014 Tacoma TRD off road
    4.5 inch backspacing, and 0mm is preferred, also -12mm for a wider stance but a little more trimming
    the trimming will come from the inner fender liner, some people just take a hack saw and cut out the area so it looks cleaner, some zip tie the plastic pieces away so if they want to reverse it they can
    the cab mount chop is needed if you want to do some extreme flexing wheeling. but normal every day driving trimming does the trick
  7. Jul 10, 2014 at 6:47 PM
    Annolino122
    Evansville
    to add to KPT:
    0" - 1.75" = 265/75/16, 265/70/17, 265/65/18
    0" - 1.75" for a wider tire = 285/65/16, 285/60/17, 285/55/18 (may need some trimming, 275 would be more safe)
    2.5"+ = 285/75/16, 285/70/17, 285/65/18 with 4.5" backspacing & 0 or -12mm offset
    2.5"+ for wider tire = 305/65/16, 305/60/17, 305/55/18 with 4.5" BS & 0 or -12mm offset
    so you can play with those numbers, but those are what i see as the most common
