Is there a trick to the 2.7 oil filter? Its messy!
Discussion in '4 Cylinder' started by snoozeworm, Mar 7, 2011.
  1. Mar 19, 2011 at 9:07 PM
    Surfinpig
    Surfinpig Well-Known Member
    Eric
    Philadelphia, PA
    10 2.7 4x4 SR5
    Avid Offroad light bar, trd skid plate, are cap, billy 5100's
    Take off then gojo arm? Works for me.
    SOSC likes this.
  2. Aug 27, 2011 at 6:39 PM
    Turp
    Turp Well-Known Member
    Virginia
    02 PreRunner SR5
    K&N panel/ snorkel removed Keyless, 2022 4Runner Wheels
    Know this is old but FWIW, I removed the skid pan and went from the bottom (No way could I reach it from the top ). I might have been able to get it without removing the skid pan but, it was late, I didn't feel like screwing around with it or getting frustrated. It is a surprise for me that Yota would locate the filter there, but I guess the engine design required it.
    Next time, I going to use a small catch pan just below the filter. Using the bag, I ended up with a mess.
    Still not as bad as some.
  3. Aug 28, 2011 at 12:40 PM
    Allen9621
    Allen9621 Well-Known Member
    Northern California
    1996 4x4 5-speed
    The combination of an old sock around the filter and thread-base, plus a plastic bag around it, can stop almost all oil spills - if you can keep it upright when you remove it from the engine.
  4. Sep 9, 2011 at 7:28 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    My procedure as well, I just try to skip the filter drop. Hate when that happens! :eek:
  5. Sep 15, 2011 at 7:49 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    I like this method!!!...will try this next change.
  6. Sep 21, 2011 at 12:52 PM
    snoozeworm
    snoozeworm [OP] taco king
    wheeling,wv
    2004 regular cab 4x4 5 speed
    Extra leaf springs in rear Pioneer head unit fj cruiser wheels 1in coil spacers siren
    Well did another oil change yesterday, took one of my old t shirts that i was gona cut up into rags and stuck the whole thing right under there. It soaked up every drop of the oil, then i just threw it away. This will be my new method of changing the filter.
  7. May 24, 2017 at 9:55 PM
    DGBG
    DGBG New Member
    Daniel
    Toyota Tacoma
  8. May 25, 2017 at 4:25 AM
    snowdrifter
    snowdrifter Well-Known Member
    Indiana
    11 SR5 AC 4x4
    Welcome to TW DGBG! But that's the wrong engine. The 2TR filter has different issues.
  9. May 25, 2017 at 11:08 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
  10. May 25, 2017 at 11:18 AM
    DGXR
    Friend
    Sacramento, CA
    I cut a piece of cardboard 6 inches by 10 inches and wedge it up between the filter and the engine block (it will mount between two of the crossmembers and stay in place, curved like a trough). Then unscrew the filter so it drains down the trough and into the pan. Leave it for a while then pull the cardboard. After this, I can easily maneuver the filter down into the pan without spilling one drop. It's super easy.
  11. May 25, 2017 at 11:30 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    That first time is a treat [​IMG]
    SOSC likes this.
  12. May 25, 2017 at 11:34 AM
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    I use this
    and a close to 24" ratchet extension. I unscrew the filter slowly until it starts to leak then push the oil pan under it, let it drip, then finish unscrewing by hand and keep upside up until I can drop it in the pan lol
  13. May 25, 2017 at 5:17 PM
    dawgn86
    dawgn86 Well-Known Member
    2013 Toyota Tacoma
    Cut a plastic milk jug open and slide it up beside filter after you have loosened it. Didn't spill a drop.
  14. May 26, 2017 at 7:12 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Can U post a pic - sounds good but I'm not good at reading directions. Thanks.
  15. May 26, 2017 at 7:55 AM
    #35
    dawgn86
    2013 Toyota Tacoma
    Forgot to take one. Basically just cut bottom off and then cut a concave shape. The plastic is flexible enough to bend up behind the filter housing. It takes a little extra time to sin off the filter but worth the no spill. Be sure the cap is on tight
  16. May 26, 2017 at 9:33 AM
    #36
    george3
    New Jersey
    Thanks 4 the reply - will try it in 5000 miles.
  17. May 28, 2017 at 11:49 AM
    #37
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    No mess for me. Service department changes mine. :D
  18. May 29, 2017 at 8:01 AM
    #38
    uwu
    uwu Well-Known Member
    At least you hope they change yours!
  19. May 29, 2017 at 8:49 AM
    #39
    CusterFan
    No worries. I have a good service department over at Dan Hecht chebby/Toyota. Not to difficult to pull the dipstick out and see clean oil on it. Sorry your service department is not up to your standards.
    http://www.danhecht.com/
    Cannot deal with the dealership on new trucks but I trust the service dept. :thumbsup:
  20. May 29, 2017 at 10:21 AM
    #40
    dawgn86
    2013 Toyota Tacoma
    I just like the chance to crawl under mine every 5k to check around for leaks , etc
