Is there a way to change the default Cruise Control?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by huskcummerbund, Dec 5, 2021.
  1. Dec 5, 2021 at 8:32 PM
    huskcummerbund
    huskcummerbund [OP] Well-Known Member
    2020 TRD-OR MT
    So, I'm still getting used to my new (to me) 2020 TRD-OR, and after trying the fancy pants Radar Assisted Cruise Control I'd like to know if there is a way to change the default cruise control to Constant Speed. I'd rather not have to hold the CC power button for 3 seconds to turn on my preferred cruise control. If I can't get it to automatically turn on with Constant Speed turned on, is there something I can disable that would make the system fail-over automatically? Like removing the radar sensor from the grille or pulling a specific fuse like I did to disable the DCM? Maybe an aftermarket module that automatically turns on CC in the preferred mode when I start the truck?
  2. Dec 5, 2021 at 8:34 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    What’s wrong with the radar mode for you? I have no complaints with it.
    DetroitZoran, BMH and BattleKat like this.
  3. Dec 5, 2021 at 8:40 PM
    huskcummerbund
    2020 TRD-OR MT
    I don't like it. I don't like how hard it hits the brakes and the distance it decides is too close (apparently a country mile is too close).
  4. Dec 5, 2021 at 8:41 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Press and hold the cruise button for a few seconds. It’ll toggle it to regular cruise mode (non adaptive)
    robin303 and sdshack like this.
  5. Dec 5, 2021 at 8:42 PM
    Otto Mation
    Otto Mation Old on the Outside, Young on the Inside
    West Texas
    2018 TRD Sport 2019 Limited
    Hold the on button until the radar message closes. It will then behave as normal cruise control.
    ETA: Got beat to the punch
    wilcam47 and uploadadventure like this.
  6. Dec 5, 2021 at 8:42 PM
    huskcummerbund
    2020 TRD-OR MT
    As I said in the OP, "I'd rather not have to hold the CC power button for 3 seconds to turn on my preferred cruise control."
  7. Dec 5, 2021 at 8:44 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Interesting. I’ve never had mine hit the brakes aggressively at all unless someone cuts me off in which case I would be hitting the brakes anyway. I do wish there was a following distance setting about one additional “bar” away.
  8. Dec 5, 2021 at 8:46 PM
    huskcummerbund
    2020 TRD-OR MT
    It hit the brakes. That's too much brakes for me.
    This behavior does give me new insight into the people I see on the road that randomly tap the brakes for no reason. They might just be on "advanced" cruise control.
    Sandfox86, SR-71A and Dirtridercrf250 like this.
  9. Dec 5, 2021 at 8:51 PM
    PFL_Customs
    PFL_Customs Pulling pitch
    2019 Tacoma Off Road
    PFL Customs roof rack, Body Armor Hi-line bumper. X20 Gen 2 Smittybilt winch, PFL Customs bed rack. Dirt bound rack supports.
    On the shortest setting im only like 30 feet behind the car in front of me at 80 mph, the longest range im a good 100 feet back there seems to be no real middle ground
  10. Dec 5, 2021 at 8:53 PM
    huskcummerbund
    2020 TRD-OR MT
    1) didn't know there was a range setting.
    2) still doesn't help with its overall behavior. If I could set it to only use engine braking I might be ok with it, but actually letting it touch my brakes is a deal-breaker.
  11. Dec 6, 2021 at 11:46 AM
    AR10Shooter
    AR10Shooter Active Member
    North Carolina
    2022 Celestial Silver Tacoma TRD OF
    I don't like having adaptive brakes set as the priority, I want control, not a computer. The following distances in my truck at the lowest setting is more like 5 car lengths distance.
    huskcummerbund[OP] likes this.
  12. Dec 6, 2021 at 11:47 AM
    huskcummerbund
    2020 TRD-OR MT
    At least I'm not the only one, even if I still don't know if it can be changed.
    AR10Shooter[QUOTED] likes this.
  13. Dec 6, 2021 at 12:03 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just saying, but OG CC could apply the brakes since the 80s.
    I've used radar cruise on rentals. It is sketchy as hell finding out if it has the ability to still work under 25 or so or come to a complete stop.
    Beyond all of that, do not bet that peeps are using radar cruise. Peeps just can't drive. Just yesterday, I saw some one tap their brakes going uphill on a highway with no one in front of them.
    Sandfox86 likes this.
  14. Dec 6, 2021 at 12:12 PM
    huskcummerbund
    2020 TRD-OR MT
    I don't think I've ever had a car that touched the brakes on Cruise Control Classic. At most they would disable Cruise if the engine braking was insufficient to reduce the speed of the vehicle coming out of the mountains in Colorado. Admittedly, that's a sample size of four vehicles from four different manufacturers since 1995, so it's not a robust dataset. The only vehicle I've ever owned that could touch the brakes is this Tacoma, and only during radar assisted cruise control.
  15. Dec 6, 2021 at 12:25 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Oh yeah. I have had CC cancel itself for speed, slip, and possibly other things.
    It was there on both a Buick and Dodge. They held speed right at the setting going down steep grades. It was only a light touch of brakes though, not like the modern stuff that has full pedal effort on tap.
  16. Dec 6, 2021 at 12:29 PM
    1taco2motos
    1taco2motos Well-Known Member
    Colorado
    19 DCSB mgm TRD OR 6MT
    And which fuse would that be?
  17. Dec 6, 2021 at 12:31 PM
    huskcummerbund
    2020 TRD-OR MT
    Hmm, weird. I think that would've freaked me out. I don't want my vehicle to touch the brakes, at all. ABS is good, but that's the end of it. Still wish I knew of a way to just power on Cruise Control in this truck and have it go straight to Constant Speed without having to hold the button for 3 seconds. I think it's just annoying that I have to bypass the default mode every time I use it. I should be able to configure which one is primary.
    AR10Shooter likes this.
  18. Dec 6, 2021 at 12:33 PM
    huskcummerbund
    2020 TRD-OR MT
    On mine, there was a 10A fuse in the fuse box under the hood in the lower left corner labeled "DCM". Pulling the fuse disables the uplink to the hive mind, but it also disables most of your microphone functionality (doesn't work for calls or search, but for some reason still works for speech-to-text when responding to messages).
  19. Dec 6, 2021 at 12:37 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    3 seconds = life time of a gnat
    or premature events his gf has to endure
    nictarine, MeefZah, jsinnard and 3 others like this.
  20. Dec 6, 2021 at 12:40 PM
    1taco2motos
    Colorado
    Drats!!!
