Is there a way to disable daytime lights?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JRinReno, Feb 27, 2018.
  1. Feb 27, 2018 at 6:28 PM
    JRinReno
    JRinReno [OP] Well-Known Member
    Jim
    Southwest Idaho
    Is there a way to disable the daytime lights on my '02 TRD? I hate running off-road in the way, way, way out-back in the day time with the lights on. On my other truck (brand C), I removed the bulbs from the daytime lights, but on my Tacoma, it is the headlights that come stay on in the day time. I hate it, but I don't want to disable my headlights for night time use.
  2. Feb 27, 2018 at 6:37 PM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    Canadian truck? I don't have daytime running lights.
  3. Feb 27, 2018 at 6:47 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I googled it way back when i first bought her. I think i cut a wire iirc.
  4. Feb 27, 2018 at 9:34 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Not sure if the '02 is the same as the '00 in this regard, but I disabled my DRLs as my first mod - hated them, hahahahaha
    My first mod - disabling the daytime running lights
  5. Feb 28, 2018 at 10:02 AM
    JRinReno
    Jim
    Southwest Idaho
    Thank you for the "education"..........it seems that these Toyota trucks were not made for the average guy to "modify" easily. I'll take a closer look at my '02 to see if it looks the same under the hood as your '00. I "might" be tempted to add a switch if I can do it without disassembling the dash. In my previous '94 (pre-Taco) I ended up taking most of the dash apart on 2 occasions; first time was to disable the chime that made noise each time the door was opened with the key in the ignition and the second time was when I added power steering and a smaller diameter steering wheel (so a person over 6' tall could get in and out without having to bend into a pretzel).
    So far, on the '02, all I have done is disable the chime so it doesn't drive us crazy when the door is opened with the key in the ignition----that mod was easier on the '02 than on the '94.
    I know someone will want to know "why" we wanted the chime to go away,........we drive out in the back country/desert quite a bit and often we get out for a minute or two to look at something interesting and we don't want to have to pull the key or listen to the chime each time we stop and get out.
    Again, thank you for your pics and answer!
  6. Feb 28, 2018 at 10:06 AM
    Cid
    Cid ╭∩╮(◣ _ ◢)╭∩╮
    Keith
    Waterbury CT
    2004 Taco 5spd SR5 TRD / 2018 HD FXBB
    ADS Coilover Front, OME Dakars with Nitro's Rear, Relentless Skids, BAMF Sliders, FN Five Star rims, 285/75r16 Falken Wildpeak, Aero Turbine 2525
    Oh shit I don't either. I didn't know they came with em
  7. Feb 28, 2018 at 10:17 AM
    JRinReno
    Jim
    Southwest Idaho
    This is not a Canadian truck, as far as I know. The original owner bought it new in Reno, NV. I have owned it for about 2 years and it has 118K miles on it. I had the 120K "tune-up", timing belt, etc performed on it right after I bought it at around 116K miles. The original Bilsteins were flat worn out so I replaced those. Otherwise I think all is original (except tires, of course).
    Thanks to all for their replies and help.
    turbodb likes this.
  8. Feb 28, 2018 at 10:43 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Sure thing!
    I wasn't a fan of the chime either - and for the same reason as you. Ditched mine by adding switches (do you sense a theme here? ;)) to the kick panels that control the light+chime. Wrote that one up here: The camping mod - disabling the courtesy lights
  9. Feb 28, 2018 at 11:55 AM
    JRinReno
    Jim
    Southwest Idaho
    OK....I went into the garage and looked under the hood at our '02.....I found the gray colored unit that you show in your photo (with 2 white/green wires coming out of it). The unit was on the driver's side near the firewall in our truck and instead of white/green wires, our unit has red wires. Now for the question: before we bought this truck, rodents had gotten under the hood and chewed up a bunch of stuff. The previous owner had the local dealership "fix" everything, but I guess they missed this part because one of our red wires (the nearest to the fender) is chewed completely in half! I have not found anything that does not work on our truck, so just exactly "what" does this wire control? My dome light works, cruise works, lights, horn, etc.,........all seem to work fine. What am I missing?
    In your photo, our corresponding broken red wire would be the lower one where you have white/green wires.
  10. Feb 28, 2018 at 12:10 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Who are you talking to and at this point what are you trying to do?
    I literally showed you where it's located for your year truck. It's the same as mine.
    turbodb likes this.
  11. Feb 28, 2018 at 12:30 PM
    JRinReno
    Jim
    Southwest Idaho
    I was replying to "turbodb" (see his photos).
  12. Feb 28, 2018 at 12:38 PM
    JRinReno
    Jim
    Southwest Idaho
    Sorry, Tashcomer, I was replying to Turbodb and what I am trying to do is turn off my daytime running lights.
    TashcomerTexas likes this.
  13. Feb 28, 2018 at 12:44 PM
    TashcomerTexas
    Ok well good luck! Lol
    turbodb likes this.
  14. Feb 28, 2018 at 12:45 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    I think what @TashcomerTexas was saying is that on an '02 (which you and he both have), the better way to do this is to use the Relay Assy Running Light in the cab (looks to be below the steering wheel if I'm understanding his picture correctly), rather than look for a wire in the engine compartment.
    I don't think that Relay Assy exists in the '00 Tacoma (what I have), which is why I went for the lights the way I did.
    As for the wire in your engine bay that is "chewed through" - I have no idea what it is. You'd have to follow it to a known location and check the pin in order to get a sense of what it's supposed to do.
  15. Feb 28, 2018 at 1:51 PM
    JRinReno
    Jim
    Southwest Idaho
    Thanks for your help! The red wire that is chewed thru will be tough to patch back together----the varmint didn't leave much to work with! I will probably try to patch it back together somehow though....I might be surprised at what it does---LOL.
    If I read correctly, TashcomerTexas is saying that cutting the wire he shows will disable the daytime running lights? I found the Asin relay and it is under the steering wheel.
  16. Feb 28, 2018 at 2:21 PM
    JRinReno
    Jim
    Southwest Idaho
    TashcomberTexas.....I'm looking at your photos and I'm seeing 2 wires that are cut: 1 has the blue electric coupler on it and the other is with your knife. Is the one with your knife the one I need to cut to disable the daytime running lights?
    Thanks again for your help!
  17. Feb 28, 2018 at 2:26 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Pull the fuse
  18. Feb 28, 2018 at 3:52 PM
    JRinReno
    Jim
    Southwest Idaho
    Sure, but would not that kill the headlights? I just want to get rid of the daytime part, not kill my headlights.....?
  19. May 7, 2018 at 5:38 PM
    JRinReno
    Jim
    Southwest Idaho
    Finally... after months of procrastinating over the drl issue, I went online and found 3 places that agreed on what wire to cut to disable the drl. All said to cut the "black wire with the yellow stripe" that goes into the Aisin drl relay (#12 position) under the dash near the steering shaft. OK, so I cut the wire and it did indeed kill the drl....BUT...it also killed my low beam headlights. All I have now is High Beam. My only recourse at this point is to buy a small rocker switch and run the "black wire with yellow stripe" thru the switch; then I will be able to turn off the drl in the daytime (if I want) and then switch on the low beam headlights for night driving.
    FYI...pulling the 7.5 amp fuse (marked DRL under the hood) will kill the headlights, period. Also, according to the Inet "experts", cutting the white/green (or white/black) wire in position #2 at the Aisin drl relay will drain the battery. I don't know, I didn't do that after reading one horror story from a guy who found out the hard way.
    Hope this info helps someone.
  20. May 19, 2018 at 7:32 PM
    scottb62
    scottb62 New Member
    Scott
    03 Tacoma Pre-Runner
    My daughter has an How do we fix it? Is there a sensor for the lights, if so, where the hell is it located? We have looked all over the Tacoma with the daytime running lights. All the lights come on in the daytime, but once night time comes, she cannot turn on the headlights. She gets the parking lamps, taillights and dash lights, but no headlights. She also has brights if she pulls the lever, but not if she pushes it forward. We have replaced the switch and checked all fuses and relays. Any ideas on why this is happening? And how do we fix it? Also, is there a sensor for the lights, if so, where the hell is it located? Thanks.
