Is there an alternative to the Rear TSB?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DavidT, Apr 21, 2010.
  1. Apr 21, 2010 at 4:26 PM
    DavidT
    DavidT [OP] D
    Pensacola, FL
    I got an 06 and just picked up a boat. The truck is sitting on the bump stops and is very bouncy. Can't get the tsb since im out of warranty. Is there aftermarket parts I could get? Im sure dealer wants an arm n leg for these parts. I could install them myself
  2. Apr 21, 2010 at 4:27 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    an add a leaf (AAL), helper springs or air bags
  3. Apr 21, 2010 at 4:35 PM
    mustangwilly
    mustangwilly Well-Known Member
    IL
    2017 DCSB OR Quicksand MT
    I had the same problem with my boat even after the TSB. I now have both air bags and the TSB and if I would have tried the airbags first I never would have messed with the TSB. Air bags are the way to go in my opinion.
  4. Apr 21, 2010 at 4:48 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Albuquerque, NM
    07 Toyota Tacoma
    Fabtech Lift on top of 3 inch body lift. 34s trail grapplers on 18inch eagle alloys. KRFab Rear bumper, BHLM with HIDs, TRD seat covers, Hood scoop, N fab tire carrier, black valence, TRD intake, 40s Flowmasters, Foglight mod, best for last and thats my 4.56 gears, and much more too come.
    You can do an AAL from toyteclifts.com but best bet since you have a boat would be some airbags
  5. Apr 21, 2010 at 5:06 PM
    05SuperChrg
    05SuperChrg Well-Known Member
    SF Bay Area
    TRD Supercharger, TRD Air Filter,Rancho 9000's, Old Man,Fumoto Oil Drain Valve,Kenwood Sub, Sony HU,Wet Okole, debadged,satoshi,Slee Sliders
    I am confused why would airbags be an acceptable solution for a truck to tow a boat? Would replacing the crappy stock springs with OME springs be the "correct long term" solution?
  6. Apr 21, 2010 at 5:21 PM
    mustangwilly
    IL
    The best thing about the air bags is they are adjustable to what you will be hauling/towing. I keep about 5-10 psi in mine at all times when not loaded and the ride isn't affected and there is no chance of bottoming out. I don't reccomend this, but if you pumped them up to 80-100 psi you could haul way more than your truck is rated for with no sagging.
  7. Apr 21, 2010 at 6:41 PM
    DSMissed
    DSMissed Well-Known Member
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    3" lift with adjustable shocks and AAL, TPS disabled, anytime locker mod, MOOG greasable ball joints and adjustment pins, URD M3 s/c, Pioneer nav headunit, xplod 1000w amp, 10" infinity sub, tinted windows, lightly tinted tails, color matched front grill with blacked out emblem. Do battle scars count as mods?? =D
    Toytec has an AAL specifically for the trucks with TSB leaf springs. Its what I got, and from what I've been told, its basically the same as what the dealership would install. Cost me about $90 shipped for a pair, had them installed myself in 3ish hours.
  8. Apr 21, 2010 at 8:27 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    X2
  9. Apr 22, 2010 at 8:13 AM
    DavidT
    DavidT [OP] D
    Pensacola, FL
    i think im going to go with this. I can install myself
  10. Apr 22, 2010 at 10:28 AM
    Baadboy11
    Baadboy11 Well-Known Member
    Lee's Summit, MO
    07 DC SB Offroad 4x4, 6spd
    Check out timbrens, super cheap, super easy to install, and you only use them when you need them. :thumbsup:
  11. Apr 22, 2010 at 10:52 AM
    DavidT
    DavidT [OP] D
    Pensacola, FL
    i might just use both the AAL and timbrens
  12. Apr 28, 2010 at 9:50 AM
    DavidT
    DavidT [OP] D
    Pensacola, FL
    how much are airbags and what kind
  13. Apr 28, 2010 at 10:03 AM
    kjf216
    kjf216 Fitz
    Kyle
    Ridley Park, PA
    2016 Jeep Wrangler Sahara
    Head unit, speakers, LEDs
    i went down to advance auto parts and picked up a spring helpers for 25 bucks and they wrok pretty good but i dont pull anything so idk how much they help with higher loads.
  14. Apr 28, 2010 at 10:20 AM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    Not OEM.
    I just bought the Firestone Ride Rites at Truckaddons.com for $260 plus 10 percent off and free shipping. Haven't installed them yet. They mount on top of the leaf spring over the axle and you have to cut off the bump stops. Airlift has air bags that mount on the leafs springs, but I think they cost a little more. Search both of these on the forum and you'll get a better idea.
  15. Apr 28, 2010 at 12:47 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    As has been posted so much before... RIDE RITE AIR SPRINGS (BAGS) and Bilstein 5100s in the back... Here is my '05:
  16. Apr 28, 2010 at 12:52 PM
    David K
    Do not inflate them that much for risk of breaking you axle... Too much air/ lift changes the rear suspention geometry and stresses the axle. Service tech at Toyota Carlsbad has seen it happen.
    The most I ever put in my Ride Rites was 45 psi... with a heavy load in back, and the truck remained high in back. With no load, I kept them at 15 psi. It doesn't talke much to lift the back and stop the bottoming out... You never need to get near the max. inflation amount, and shouldn't!
