Is there an HID kit that has no issues?
Discussion in '3rd Gen. Tacomas (2016+)' started by Jmichaelh7, Nov 12, 2017.
  1. Dec 20, 2017 at 8:55 PM
    #101
    Vbpiper
    Vbpiper Well-Known Member
    2016 BBP SR5 DCSB 4x4
    AVS Bugflector II, WeatherTech mud flaps, Gentex Homelink/compass mirror, OEM bed mat, SolidFold 2 tonneau
    I have had my Xenon Depot H11 kit installed on my Tacoma for several months and couldn't be happier with it, so I installed one in my wife's 2011 Highlander, but this time without the relay harnesses. What an improvement from the stock halogens.
  2. Dec 20, 2017 at 10:00 PM
    #102
    the_dau
    the_dau Well-Known Member
    Vancouver BC
    2017 Inferno TRD OR DCSB
    I've had my Xenon Depot HID's for almost a year now. no issues with output or bounce whatsoever. I originally went with the 4300k Phillips which gave me great output, but didn't match my Morimoto fogs very well
    Vbpiper likes this.
  3. Dec 21, 2017 at 9:08 AM
    #103
    temujen
    temujen Well-Known Member
    '17 Tacoma OR DCSB
    Installed the DDM Plus Canbus kit on my '17. If you scroll down on this page, you'll see pics/details of the before and after. No bouncing, static or anything like that as of yet!
    Also, I should mention that they don't actually match the DRL's exactly, it's just that they overpower them so much you can't really make out the DRL's. Fine with me.
  4. Dec 21, 2017 at 1:58 PM
    #104
    bergerob
    bergerob Member
    2017 Trd Pro
    Is there any write up with pics on how to do the RX350 retrofit?
  5. Dec 21, 2017 at 6:28 PM
    #105
    the_dau
    Vancouver BC
    heat up the headlight, take it apart. unbolt the stock projector and bolt in the new one. it's that simple
  6. May 15, 2018 at 1:23 PM
    #106
    jayandersen5
    jayandersen5 Active Member
    Jay
    Charleston, SC
    2017 Tacoma TRD Sport DCSB
    MESO LED Interior Lights MESO Ultimate Turn Signals v4 Morimoto HID Elite System Yeaky 5500k HID Bulbs Morimoto XB LED Fog Lights AJT Designs Key Fob OEM Tonneau Cover OEM Predator Tube Steps Cubby Covers Bed Mat Tufskinz inserts
    After driving with my Morimoto HID Elite system since last October, I finally couldn't take the bouncing issue anymore as it seemed to get progressively worse. TRS likes to say is it an issue with the factory projector, however, I recently purchased a pair of Yeaky 5500k HID bulbs and have no bouncing whatsoever. I still run the Morimoto 55w ballasts and the rest of the Elite setup other than the bulbs. Plus the Yeaky bulbs also have a whiter color (personally prefer it over the Morimoto 5500k). It seems the issue IS with the Morimoto HID bulbs included with the HID Elite system from TRS and not with the factory projectors...
    Yeaky HIDs link: https://www.distantxtremes.com/store/p1017/H11_/_H11B_5500K_YEAKY_HID_Wired_HID_Bulb_Pair.html
  7. May 15, 2018 at 1:29 PM
    #107
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Does the Philip 4300K color match the LED strip?
  8. May 15, 2018 at 9:57 PM
    #108
    patdeezy
    patdeezy Well-Known Member
    souL.caL
    SSM '16 TRD Sport DCSB
    +1
  9. May 16, 2018 at 4:40 AM
    #109
    1bad2k
    1bad2k Well-Known Member
    DFW, TX
    2017 Tacoma TRD PRO
    Yes, Osram or Philips bulbs and denso ballasts. All OEM it the way to go.
  10. May 16, 2018 at 7:03 AM
    #110
    El Latigo
    El Latigo Well-Known Member
    Anaheim CA
    2017 MGM TRD OR Double Cab Short Bed
    Been running GTR Lighting 55w Pro Single Beam HID Conversion Kit HID Bulb. 6,000K Diamond White, HID Bulb with no issues.. I like the light output bright
  11. May 16, 2018 at 7:45 AM
    #111
    arnette64
    arnette64 Well-Known Member
    Amos, Qc (Canada)
    2016 Inferno TRD Sport Double Cab 4X4
    '16 Inferno TRD sport DC
    Same situation for me, mine bounce as well, TRD Sport.
    XenonDepot Xtreme HID with Philips bub.
    Facts Only likes this.
  12. May 16, 2018 at 12:15 PM
    #112
    XenonDepot
    XenonDepot Well-Known Member Vendor
    Careful with 55W HID bulbs. You end up getting 50W ballasts mated with 35W bulbs. This means that you end up overdriving the 35W bulbs which means that they will burn hotter, burn out prematurely, and will cause more glare due to the bigger arc.
    El Latigo likes this.
  13. May 16, 2018 at 4:08 PM
    #113
    no vtec 4me
    no vtec 4me Well-Known Member
    Kevin
    West Chester, Pa
    There is more to it than that
    arnette64 likes this.
  14. May 16, 2018 at 4:49 PM
    #114
    ParadizeCityz
    ParadizeCityz Well-Known Member
    Richmond, TX
    2017 Toyota Tacoma SR5
    Thinking of getting @XenonDepot
    Do I get the 35w or 55w?
  15. May 16, 2018 at 4:59 PM
    #115
    Vbpiper
    I have the 35W and it puts out plenty of light. My concern with the 55W was the potential for long-term damage to the housing. OEM HIDs are 35W.
    From DiodeDynamics.com:
    "At Diode Dynamics, we only offer 35W bulbs and components, as 55W bulbs produce an excessive amount of heat, which can damage the headlight or foglight housing, and have a much shorter lifespan. "
    You will certainly get differing opinions, but that was my reasoning.
  16. May 16, 2018 at 6:58 PM
    #116
    the_dau
    Vancouver BC
    not really. aside from cutting a notch if you're using the rx350 projectors
  17. May 16, 2018 at 7:18 PM
    #117
    1bad2k
    DFW, TX
    2017 Tacoma TRD PRO
    It's not the housings that have a problem. In fact the 55w hid probably still make less heat than the factory halogens. The issue is the bowl of the projector gets scorched from the extra UV of the higher powered hid kits and then reflects less at that point. Then you have issues.
  18. May 16, 2018 at 7:22 PM
    #118
    El Latigo
    Anaheim CA
    So a 55 Watt HID bulb is not available?
  19. May 16, 2018 at 7:30 PM
    #119
    Vbpiper
    I would consider the bowl to be part of the housing, so whatever works for you. :thumbsup:
    1bad2k likes this.
  20. May 16, 2018 at 7:42 PM
    #120
    ParadizeCityz
    Richmond, TX
    Thank you! I'll probably get the 35W for my truck and my wife's Highlander :)
    Vbpiper likes this.
