is there any enclosures out there that requires no cutting or drilling?
Discussion in 'Audio & Video' started by chaos316, Oct 3, 2011.
  1. Oct 3, 2011 at 8:08 PM
    chaos316
    chaos316 [OP] Well-Known Member
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    285/75/16 BFG KO2 Ditch Lights
    I have a 2011 double cab and i am wanting to add either 1 or two subs. but i do not want to cut or drill ANYTHING. I'm fine with taking the storage bins out, but i do not want to hammer down or cut off those brackets that hold the storage bins in place. Just wondering if anyone has built anything like this, because i would like it to be easy to take the enclosure out, and put the storage bins back in and return to stock. If anyone has dimensions they could share that would be great!
  2. Oct 3, 2011 at 9:11 PM
    pinktaco808
    pinktaco808 Hot Steppa
    bazooka
  3. Oct 3, 2011 at 9:14 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Check out SuperCrewSound.com I've had 3 boxes from them they have all come in a timely manner, very high quality boxes, if you don't like it or it won't fit send it back no questions asked as long as you haven't drilled the subs or connecters in.
  4. Oct 3, 2011 at 9:16 PM
    rcfreak201
    rcfreak201 Well-Known Member
    check out groundshaker as well
  5. Oct 4, 2011 at 12:42 AM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    so none of those boxes require cutting or drilling or flattening anything?
  6. Oct 4, 2011 at 6:52 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    +1, they are no MrMarv box, but they are good enough for me. The boxes don't require any mods except removal of the storage bin(s). You can get a single or double sub box. Soundoffaudio.com has the same/similar boxes. You can also figure out just the dimensions from their web site if that's what you want.
  7. Oct 4, 2011 at 5:58 PM
    mrmumbels
    mrmumbels Well-Known Member
    Land O Lakes, fl
    09 prerunner
    none
  8. Oct 4, 2011 at 6:35 PM
    Warhorseforever
    Will
    Sand Lapper
    SCS requires removal of all plastics on the back but no cutting of the child restraint bars across the back. It also has an amp rack so you don't have to do like me and worry about people stepping on the amp or water from wet feet finding its way to it.
  9. Oct 4, 2011 at 6:37 PM
    Warhorseforever
    Will
    Sand Lapper
    You also can get a triple.
  10. Oct 4, 2011 at 10:45 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    I'm talking about cutting any brackets, or anything that could restrain me from completely changing everything back to stock, including the brackets that bolt up TO the storage bins
  11. Oct 4, 2011 at 11:27 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    would three 10" w1s compare to 1 or maybe 2 jl tw5 13"?
  12. Oct 4, 2011 at 11:29 PM
    pinktaco808
    maybe 30 to 26
  13. Oct 5, 2011 at 12:02 AM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    30 to 26? what in the world does that mean
  14. Oct 5, 2011 at 3:10 AM
    b2200srunnin
    b2200srunnin Pipeliner
    Dustin
    Columbus, MS
    09 4x4 trd pkg
    Foglight mod, Toytec Ultimate lift, Dakar leaf pack, Retros by Ant, led lights inside and out, URD TCAI/MAF sensor, Aero 2525 muffler, BFD 18x9 Matte Bronze wheels, Relentless Aluminum front bumper and steel rear bumper, 76mm Throttle body, '13+ mirrors with blinker lights, complete audio upgrade
    Probox is another option that requires no cutting or drilling comes with two 8's in a ported box. Ive been told it sounds better than the jl stealth box by the local jl dealer.
  15. Oct 5, 2011 at 6:51 AM
    pinktaco808
    sorry, that the cone area soo maybe it would be louder with the right power and box the 3 10
  16. Oct 5, 2011 at 6:52 AM
    pinktaco808
    Id say go 4 8 ported be loud
  17. Oct 5, 2011 at 6:55 AM
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    I have a JL 13w5 behind my seat, only thing done is had the plastic inserts taken out and the plastic on the seat back taken off. I have wet okoles so you cant see the seat plastics gone
  18. Oct 5, 2011 at 9:13 AM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    do you have the plans for that box? and what amp are you running?
  19. Oct 5, 2011 at 9:22 AM
    crazyengineer
    patrick
    Bristol, TN
    the box is just one you can buy with the sub, sub and box combo were 500, premade, etc.... from my local audio shop
    the amp driving it is a JL Audio J2 500.1 Class D Mono Amplifier
    sounds really good, i like it, its more than enough for my double cab, and you keep part of your behind seat storage
    there is another 1000 watt (nitro amp, not as good as the JL), but it is powering my door speakers (infinitys)
  20. Oct 5, 2011 at 9:40 AM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    alright thanks a lot. so thats just a box you bought? because most of the boxes are like 7.25" in depth. will those fit back there?
