Is there any horizontal headlight adjustment possible?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EdinCincinnati, Jan 8, 2016.
  1. Jan 8, 2016 at 7:17 PM
    EdinCincinnati
    EdinCincinnati [OP] Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    I know how to adjust vertically but my right beam projects too far left on the horizontal plane - passing the beam projection of the left headlight. It's really annoying when driving through fog. Any suggestions how to correct?
    The fixture appears to be seated correctely, gaps against hood and side panel are consistent. I've never been in an accident with this truck or removed the headlight.
    And Yes, I have searched and read all the threads on headlight adjustments that I could find in the 2nd Gen forum.
  2. Jan 8, 2016 at 7:18 PM
    Wile
    Wile Well-Known Member
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
    tinker_troy, AJ1001 and tomwil like this.
  3. Jan 8, 2016 at 7:23 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    Excellent!!! Thank you @Wile!!!
  4. Jan 8, 2016 at 7:27 PM
    Wile
    Tim
    New Mexico
    :thumbsup:
  5. Jan 30, 2016 at 5:53 PM
    Johnny2525
    Johnny2525 Well-Known Member
    California
    '14 TRD OFF ROAD DCSB
    ICON stage 3 suspension kit, Amp Research retractable steps, LED interior lighting, headlights, fog lights, MB wheels, FlowMaster exhaust. Rigid Industries back up lights, aFe Cold Air Intake with URD MAF sensor Calibrator
    Only interested in horizontal adjustment
    OK, 2 things....no.1. Which way do you spin it to get the driver side to move in. It points out. no.2. I already tried moving it both ways and do not see it moving at all. What am I doing wrong?
    TacoTrooper likes this.
  6. Jan 30, 2016 at 6:20 PM
    LinBaba
    LinBaba Active Member
    Andrew
    2012 Toyota Tacoma White TRD Sport
    If it doesn't move turning it one direction, move it the other direction, I just adjusted my headlights 10 minutes ago and had the same issue, it "maxes out" and stops at some point, so go the other direction, after a few turns you can adjust it using your fingers, don't forget to snug it back up by doing a small turn clockwise to finish
  7. Jan 31, 2016 at 10:24 AM
    Johnny2525
    California
    You were absolutely correct sir. I have been obsessing over getting this right for a week. Thank you for your help.
    LinBaba[QUOTED] likes this.
  8. Jan 31, 2016 at 11:07 PM
    RobD
    RobD Well-Known Member
    Rob
    Calgary
    2013 Spruce Mica Tacoma Double Cab TRD
    Sort of related note: my 2013 had terribly aligned headlights from day one. Great for illuminating the tops of trees on the left side of the highway and pissing off oncoming drivers, especially tractor trailers. Stopped at a Toyota dealership and asked the service advisor if there was someone who could align them for me. Their reply: "I don't think you can. They're set at the factory". Um, really? Can I speak to someone who doesn't have their head up their ass? Was referred to a local autobody shop they use, related my story to another blank faced SA, but was fortunately overheard by a shop guy. He had them both aligned in about ten minutes, at no charge to me.
  9. Feb 1, 2016 at 7:01 AM
    Johnny2525
    California
    I was told the same thing from the local dealer. No way to adjust. Go figure.
    RobD likes this.
  10. Nov 12, 2016 at 5:51 PM
    jet123
    jet123 Well-Known Member
    Ft Collins
    2013 DCLB
    Reviving this thread as no matter how many turns (upwards of 40 full turns) in either direction, I can see discernable difference in the horizontal plane. I watched to make sure I am actually turning the plastic white cog as I turned the screwdriver as well. And to clarify, I am only turning 'B' in the above diagram. I am doing this out on a dark dirt road with pretty even & constant treelines on both sides.
    In the several threads on this topic, it seems all I should have to do is put in the screwdriver & turn. But is there some type of release I am missing before turning the cog? Or does it sound like my horizontal adjustment is broken?
  11. Nov 13, 2016 at 7:19 PM
    jet123
    Ft Collins
    2013 DCLB
    Once I started watching the housing, I do have horizontal adjustment on both headlights. But I can see no discernable change in light placement as I take a housing from one stop to the other. So I placed them both in the middle of the sweep range and find a good place to do a proper headlight adjustment.
  12. Nov 13, 2016 at 8:23 PM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    my headlights are all a mess, I pointed the truck at the garage door and covered up one headlight with cardboard and adjusted the other one while watching the beam on the garage doors up and down and back and forth, right and left... nothing happened. I dont know whats up with that... it dont make sense to me at all.
  13. Oct 15, 2017 at 4:29 PM
    Roy99
    Roy99 New Member
    Recently replaced my 2011 Tacoma headlights and had some adjustment issues as well. I found that trying to adjust them in the garage was near impossible, because you are too close to the wall. A very small change at 5 feet results in a much larger difference at 25ft. Backing off to 20-25 feet made all the difference.
    yotaTom likes this.
