Is there any reason that I couldn't/shouldn't cut the Exhaust right behind the Axle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RearViewMirror, Apr 29, 2013.
  1. Apr 29, 2013 at 11:02 AM
    RearViewMirror
    RearViewMirror [OP] Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Title says it all. I hate the way the exhaust looks hanging off the back of the truck. Is there any reason that I couldn't / Shouldn't cut the exhaust off on the downturn right after it goes over the rear axle? I was going to put a small tip painted black to go on the end of it once it's cut? Any negative effects?
    Thanks in advance
  2. Apr 29, 2013 at 11:04 AM
    RearViewMirror
    Craig Christ
    Ah... good point. Never thought about that.
  3. Apr 29, 2013 at 11:05 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Well I guess that solves that.
  4. Apr 29, 2013 at 11:07 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    most wheelers cut it off after the axle.
    also digging the stephen lynch nod.
  5. Apr 29, 2013 at 11:09 AM
    RearViewMirror
    Craig Christ
    Haha... You're the first one to get it! Good Job
  6. Apr 29, 2013 at 11:16 AM
    magnetic11
    magnetic11 Well-Known Member
    "some nuke plant"
    11 trd sport
    Fab fours front and rear bumpers, B.A.M.F. weld on rock sliders, softopper, removed mud flaps and D-Badged everything. Icon 2.5 Extended Travel coil-overs, Total Chaos upppers, 2.0 Icon extended travel shocks with the resi's and Dekar Leaf packs.
    MagnaFlow Makes A System Like This. Its The Pro Off Road Series. I Have It On My Truck, Im Still Kicking. And Sitting In Traffic Is A Big Part Of My Day.
  7. Apr 29, 2013 at 11:21 AM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    Me and a couple other first gens cut ours off maybe 7-8 years ago, just past the axle. No issues. 2nd gen.... not so sure.
  8. Apr 29, 2013 at 11:22 AM
    RearViewMirror
    Craig Christ
    I figure I'll cut it off. I can't stand the look and I don't want to get it hung up on anything. If I die I'll die looking good ;)
  9. Apr 29, 2013 at 11:23 AM
    BamaToy1997
    Bill
    Navarre, FL
    The carbon monoxide risk is not a 100% given. It is simply a fact that idling in traffic DOES cause it to build up under the cabin and bed. While many have obviously had no ill effects that they know of from this, the risk is still there. Also, carbon monoxide poison does not always kill. It can cause headaches and other problems as well.
  10. Apr 29, 2013 at 11:52 AM
    The_Hodge
    SC
    it cant get under the cab from behind the rear axle. only way it would is if there is a leak before the bed or if someone chopped the exhaust before the bed. the gasses would rise between the cab and bed.
  11. Apr 30, 2013 at 5:42 AM
    BamaToy1997
    Bill
    Navarre, FL
    You would think so, however it can still get there. The fumes build up under the bed quickly, and then as they escape they can get under the cab still. There has been numerous tests performed by GM, Ford, and Dodge years ago. One of the courses I took when I was training for GM was specifically on exhaust leaks and carbon monoxide. It covered the many ways it is possible for a leak that is under the bed to get into the cab.
  12. Apr 30, 2013 at 6:50 AM
    Limitless
    Limitless Well-Known Member
    Scott
    NW Illinois
    12 DCLB White TRD
    De-badged, Tinted Windows.
    My 2001 Extended cab was chopped off in front of the bed cab seam, it was fine. If you sat still on a completely calm day you may get a hint of the exhaust, but in most cases, there is enough moving air around your truck even when stopped to dissipate any high level emissions.
    The cab pressure release vent should only open with positive cab pressure, like when closing your doors. Most likely source of these emission gasses entering your truck, an open window, not some tiny little hole. Path of least resistance.
    Just Sayin.
  13. Apr 30, 2013 at 6:55 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I always thought carbon monoxide was heavy and would lay low.
  14. Apr 30, 2013 at 6:58 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Keep in mind, if you're sitting in traffic you will likely either have the windows open or the HVAC fans running and windows closed. Windows open, no big deal, windows closed, the cab is slightly pressurized from the fan so while there is a very slight risk of CO seeping into the cab while sitting in traffic, it's not likely. How many large box trucks have theose turn down exhausts right after the muffler, just after the cab? Unless you have a shell and keep animals in the shell, I wouldn't be overly concerned with CO poisoning as a deterrent.
  15. Apr 30, 2013 at 7:01 AM
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    BAMF kick out sliders, SkidRow skids,Pro Comp 7069, Kelly Safari TSR 285's, Elite front bumpa, OME 883 & Dakars w/ D6XL AAL, Nitro sport shocks, Eddie209 Soft topper, Satoshi, k&n fipk, Clarion vx400, Ultra Gauge, Debadgination mod
    1st gen here. Cut my pipe right after the axle. No issues!
  16. Apr 30, 2013 at 7:10 AM
    RearViewMirror
    Craig Christ
    CO is slightly lighter than air but mixes very well with it (byproduct of being a HazMat Tech with my job). The amount of moisture, temp, etc... has to be taken in to account also.
    I actually started this thread with more of a concern with a performance / damage issue that may arise by cutting my exhaust after it turns down over the rear axle not CO levels (although very important and something I didn't consider).
    My personal opinion (everyone has one) is that: if you are sitting in traffic even on a calm day that the exhaust would dissipate before it entered your cab unless you had your windows down. As someone stated earlier the pressure vents (if working properly) should hold out most of the exhaust. Along this line of thinking... If sitting still in traffic I personally think that you would be getting a fair share of other peoples' exhaust along with yours. This of course is just my opinion and not a definitive answer. I'm still undecided if I am going to do the mod or not.
  17. Apr 30, 2013 at 7:12 AM
    BostonBilly
    Easton
    What about state inspections. Will it pass
  18. Apr 30, 2013 at 7:18 AM
    RearViewMirror
    Craig Christ
    On a side note Pugga, I changed my PIAA's to the High Beam Circuit. You were right.
  19. Apr 30, 2013 at 7:18 AM
    The_Hodge
    SC
    it wont cause any performance issues. lots of folks have it done w/o issue.
  20. Apr 30, 2013 at 7:19 AM
    RearViewMirror
    Craig Christ
    Oddly enough Arkansas doesn't do state inspections anymore. Stopped that over 20 years ago. Backwards fucking state. No way it would pass in Cali I bet lol
