Is there anyway to add a third seat belt along the back to the extra cab of a Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by yfz450admirer1, Jun 30, 2013.
  1. Jun 30, 2013 at 3:57 PM
    yfz450admirer1
    yfz450admirer1 [OP] Member
    Is this possible? There are two jump seats in the extra cab, but I would like to have a third seat belt in the middle.
  2. Jul 20, 2013 at 7:58 PM
    yfz450admirer1
    I would really appreciate some feed back on this. I am going to check out what jeeps use to add seats.
  3. Jul 20, 2013 at 8:08 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Maybe a lap belt, add to existing bolts in center and at the end maybe? Could use center belt out of a 4Runner.
  4. Jul 20, 2013 at 8:13 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    not really...the person would be sitting right where the 2 actual seat belts buckle in. i cant see this being worth it at all or being safe at all. there is no room back there as is, how are you going to fit an extra person?
  5. Jul 20, 2013 at 8:33 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I could fit there... Haha
  6. Jul 20, 2013 at 9:07 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    You should have bought a double cab for fitting 5 people in
  7. Jul 21, 2013 at 12:01 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Who in the hell can fit there with two other people back there?!
    No. Trust me I've had e whole cab apart. No safe way to attaché another belt.
    Plus as it was pointed out. The middle person would be sitting n the two current seatbelt s.
    Should have bought a double cab for 5 people..and even then that's still not comfortable.
  8. Jul 21, 2013 at 12:38 AM
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Agreed with Monte. Have someone else drive your truck next time you have a full load and you sit in the back then think about if you really wanna put another seat back there in the middle... I would not recommend it :confused:
  9. Jul 28, 2013 at 3:31 PM
    yfz450admirer1
    I would appreciate any more constructive ideas on how to make this work.
  10. Jul 29, 2013 at 7:09 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I think you will have to make your own seats and relocate the seat belts to work. It's a tight fit though so your kinda out of options. Maybe look into some third row seats with built in seat belts and trim them to fit. Not at all safe but remember making your kids ride in the bed back in the day??
  11. Jul 29, 2013 at 8:19 AM
    ethanfoy
    ethanfoy Well-Known Member
    ethan
    Little Rock AFB
    99 toyota tacoma xcab 4x4
    I want to put a colorado back seat in mine it looks like it will fit i havnt had time to take measurements. and they are so comfortable.
