Is there benefit in flooring tacoma once in a while
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sh56, Jan 27, 2024.
  1. Jan 27, 2024 at 4:19 AM
    Sh56
    Sh56 [OP] Well-Known Member
    Shara
    2022 Lunar Rock Tacoma TRD off road
    I heard it’s good to get in highway once in a while and floor the car and let the engine breathe and get rid of all gunks and carbon deposits.
    does that apply to the Tacoma’s 3.5 littler D4S engine?
    After putting 30k mile on my 2022 tacoma today I gave it a good floor in highway. Is that good and healthy for the longevity of the truck and engine or should I not doing at all not even once in a while.
    Irons and GTGallop like this.
  2. Jan 27, 2024 at 4:30 AM
    jbjones85
    jbjones85 Well-Known Member
    Josh
    Newburyport, MA
    You will get many opinions on this topic, much like what is the best oil.
    Personal OPINION - It's not needed and just drive as you would. Given the power (or lack thereof) I find that just in normal driving it gets exercised pretty often. At the end of the day it's your truck, so you do you, just make sure the engine is fully warmed up otherwise it could be harmful in the long run.
  3. Jan 27, 2024 at 4:33 AM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Question asked a day late; this definitely belongs in the "Friday" post section.
  4. Jan 27, 2024 at 4:36 AM
    Old goat1914
    Old goat1914 Well-Known Member
    Chicagoland, Indiana
    2016 TRD Sport DCLB 4x4
    I don't know the answer to your question. Are you using a Top Tier rated gasoline brand like the owner's manual recommends? These brands help limit the build-up of gunk inside the engine with extra detergents (more than the bare minimum required by the government).
  5. Jan 27, 2024 at 4:37 AM
    Sh56
    Shara
    Yes I only put chevron gas
  6. Jan 27, 2024 at 4:38 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    In my youth we called that an Italian tune up.
    Pwakchop, Jaragon, eurowner and 25 others like this.
  7. Jan 27, 2024 at 5:08 AM
    pushgears
    pushgears Well-Known Member
    2021 OR DCSB MT
    I think it's good to "open her up" once in a while ;-) without abusing the engine. That is - operate it at a range of RPMs.
    Irons and 4x4Taco2012 like this.
  8. Jan 27, 2024 at 5:11 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Tacoma has plenty of power available, just have to use the skinny pedal.
    I rarely floor it, usually only when passing.
    Junkhead likes this.
  9. Jan 27, 2024 at 5:21 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    Once in month I will open her up to 85 MPH,watch my RPM so I don't red line for about a mile or so. I guess it is up to you. just saying
  10. Jan 27, 2024 at 5:23 AM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
  11. Jan 27, 2024 at 5:44 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    turn tunes off, roll down windows, and smash it. no sweeter sound than a rev'd V6 turd gen tacoma. :turtleride:
  12. Jan 27, 2024 at 6:28 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    We still call it that. (Am I getting old? Don't know. I'm not a youth anymore)
    OP:
    The way I see it, you paid for the whole rev range, you ought to use the whole range. Every now and then I'll use 100% power on the freeway on ramp for fun. And sometimes passing on the highway asks for full throttle (especially in the fat 4R).
    On the flip side, engines that barely see any revs (or pressure) do have issues more often, so a happy medium would be better, at least.
    +1 on wait until the engine is warm before WOT shenanigans.
  13. Jan 27, 2024 at 6:36 AM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    Three points to that logic.
    It is good to get your Tacoma (any car and especially those that have a turbo) up to operating temps and run the engine for about 30 to 45 minutes at normal RPM's once every couple of weeks. This lets all of the moisture that condensates inside the engine cook out of the oil.
    It is good to get your Tacoma (any car and especially those that have a turbo) up to operating temps and then have a spirited run (higher RPM's mean more exhaust flow) onto the freeway once every couple of months to clear out the catalytic converters. Much less of an issue now than it was in the 1980's because cats are made better and are mounted closer to the engine where they stay warmer, but still beneficial none the less.
    It is good to get your Tacoma (any car and especially those that have a turbo) up to operating temps and then whomp on that skinny pedal because your soul wakes up. :burnrubber:
    Irons, soundman98 and 4x4Taco2012 like this.
  14. Jan 27, 2024 at 6:38 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    If it had a carburetor, I might see the benefit.
    In a Tacoma, it's just going to remind you of how under powered it is.
  15. Jan 27, 2024 at 6:49 AM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I take it up to about 85mph all the time. That's about my cruising speed on the freeways where I live.:anonymous:
    asuchemist likes this.
  16. Jan 27, 2024 at 7:02 AM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    I'm to scared to let all that power out at once
    Junkhead, Woofer2609, Irons and 4 others like this.
  17. Jan 27, 2024 at 7:04 AM
    GTGallop
    Greg
    Anthem, Arizona
    Dash Cams and Hams!
    You just have to factor in the coriolis effect and adjust accordingly so you don't throw the earths rotation off. Totally safe if done right.
  18. Jan 27, 2024 at 7:26 AM
    Veet-88
    So much torque it twisted the chassis
  19. Jan 27, 2024 at 7:36 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Send it...
  20. Jan 27, 2024 at 7:38 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i worry about my passenger side floorboard every time i open it up.
    but really, the biggest joy in revving the truck up is hitting the second set of intake tracts at 4k rpm, keeping the motor singing all the way to redline, and then letting the front end bounce like an old gasser in between gear shifts. the bounce makes it feel like there's actually power to control!
