Is there benefit in flooring tacoma once in a while
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sh56, Jan 27, 2024.
  1. Jan 27, 2024 at 9:29 PM
    #41
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    I always give it what it needs, I'm not concerned with going over any RPM's either accelerating or heading down a steep mountain pass using engine breaking. We recently lost our 2nd vehicle. So it's been just the truck. My Commute is just long and varied enough to exercise the RPM range and burn off any condensation. Too many short trips these days by my wife after I get home from work. So I like to give'er once it's fully up to temp when I can.
    Just the other day I drove the wife over to the nearby grocery store on a dank and damp evening. It was hovering just over the freezing mark outside. I waited outside with the truck idling. We left and stopped at the intersection waiting for the light to change. Truck was just barely up to operating temp. Advanced left turn light turned green. As I finished the turn there is a steep hill. No one was around. I hit the throttle. I think the auto trans shifted to 2nd climbing to an easy 5k RPM. held it there, then slowed down for the crest of the hill to make a right turn.
    In my rear view mirror, there was this huge thick cloud of condensation that I left behind. Kinda embarrassing leaving that along with the scream of that little V6. It was a bit of a spectacle. Was satisfying at the same time getting all that condensation out of my DCLB's exhaust system and engine. Reminded me of my old work Ford Power Stroke diesel. If you idled too long warming it up in winter. There was this huge, thick cloud, of eye watering exhaust that was choking anyone behind you as you moved down the road.
  2. Jan 27, 2024 at 10:07 PM
    #42
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    But wrong on a couple points there...
    RPM + mass air matters, so accel > decel due to throttle position
    Your engine sucks in the full amount in one stroke, it just holds onto it for longer
    Schlappesepple likes this.
  3. Jan 27, 2024 at 10:50 PM
    #43
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    IMO, a long steady multi-hour drive with a fully heated engine does more to clean out the injectors, clean off the intake valves, burn off any bypassed fuel in the oil, and evaporate any water in the oil supply than an occasional rabbit acceleration.
  4. Jan 27, 2024 at 11:11 PM
    #44
    Irons
    Irons Outlaw Prospector
    NW Michigan USA
    '22 TRD Sport AC MT Army Green
    TRD lift, Exhaust & CAI
    Yes, it's called a Italian tune up. Get that girl out onto the highway and give it the beans, then set your cruise control at the max MPH you can go without getting a ticket and let it run for a while like that. Burns off any deposits and also burns off any water in the system from condensation.
    I'm not saying go out and beat on it, but letting it run once or twice a week is better than babying it on short trips where it rarely gets up to full operating temp.
    .:burnrubber:
    Junkhead and soundman98 like this.
  5. Jan 27, 2024 at 11:22 PM
    #45
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    I floor mine daily.
    :thumbsup:
    Junkhead likes this.
  6. Jan 27, 2024 at 11:25 PM
    #46
    Irons
    NW Michigan USA
    I get to compare it to my other v6, a GM 4.3 so yeah the Tacoma sounds good. My Tacoma has TRD intake and exhaust and while it doesn't sound like a big block V8 it does have a nice refined rumble to it. My 4.3 has 2 1/2 inch pipes, no cat and a good quality turbo muffler and honestly it sounds..........cheap.
    The Tacoma sounds tight, like it's well made. I love my old S10 but it sounds like huffa huffa huffa!
    Junkhead and vivid02 like this.
  7. Jan 28, 2024 at 12:30 AM
    #47
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    That's opening it up at 85 MPH? On my truck thats around 2200 RPM. During the winter I drive from Palm Coast to Ormond Beach and back almost everyday. Around 85 in the norm, sometimes I drive a spot faster. Even at 96 MPH it's no where close to the red line.
    My radar detector has paid for itself many times over.
  8. Jan 28, 2024 at 3:12 AM
    #48
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    This sounds like a myth than a fact that It does anything … heat alone is not going to clean the engine from carbon deposit . U need some kind of cleaner additive like sea foam .
  9. Jan 28, 2024 at 4:36 AM
    #49
    I.eat.tacos
    I.eat.tacos Well-Known Member
    Steve Rogers
    '18 TRD 4x4 Sport
    Benefits?
    Flooring it for me is the smiles of feeling fast again. Feels like I'm "Fast and Furious", but in reality I'm "Slow and Gentle".
  10. Jan 28, 2024 at 5:13 AM
    #50
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I owned a C6 Corvette with the 434 HP LS3 motor that would pin you to the seat when floored. I am thinking flooring my pickup truck motor will be somewhat of a disappointment.
    Irons likes this.
  11. Jan 28, 2024 at 6:54 AM
    #51
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    *big wheel
    Irons likes this.
  12. Jan 28, 2024 at 6:55 AM
    #52
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    air/fuel ratio's dictate that if you're slowing down, and engine braking, the motor increases it's air intake amount because fuel is largely cut off from entering the combustion cycle.
    GTGallop[QUOTED] likes this.
  13. Jan 28, 2024 at 7:01 AM
    #53
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Say what?
  14. Jan 28, 2024 at 7:03 AM
    #54
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    OP, if you want to floor it, give Mode Loco a try on a gravel road with plenty of space. 4LO-ETC-TRAC off, and give her the full beans :alien:
  15. Jan 28, 2024 at 7:07 AM
    #55
    soundman98
    NW Indiana
    if the motor isn't making power, fuel isn't needed.
  16. Jan 28, 2024 at 7:09 AM
    #56
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Soundman, You've got it a little backwards, and the order of control is different, too.
    You control how much air the engine gets by opening / closing the throttle. The engine looks at how much air is coming in and adds an appropriate amount of fuel for combustion. More air = more fuel, and vice versa.
    Technically we should call the gas pedal the air pedal.
    For GTGallop: you're right that the volume of air is the same at full or partial throttle, since that is based on the engine displacement. However, the pressure is different (atmospheric pressure at WOT, partial vacuum anywhere else).
    At lower pressures, the air density is lower and you pull less mass of air through the engine. And it's the mass of the air, not volume, that determines how mich fuel to add for combustion. (Hence the mass airflow sensor).
    Phlogiston, GTGallop and soundman98 like this.
  17. Jan 28, 2024 at 7:20 AM
    #57
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I think it was more beneficial in days of carbureted engines and really doesn't matter as much today. But also, never hurts to exercise those ponies every now and then and see what she's still got.
  18. Jan 28, 2024 at 7:36 AM
    #58
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Huh. You mean my 4cylinder will hit 88mph?
    davidstacoma[QUOTED] likes this.
  19. Jan 28, 2024 at 7:42 AM
    #59
    Horseshoez
    Dale
    Maryland
    Not what I was questioning, it was the increased air.
    soundman98[QUOTED] likes this.
  20. Jan 28, 2024 at 7:54 AM
    #60
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Do you mean before the TB?
