Is there benefit in flooring tacoma once in a while
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sh56, Jan 27, 2024.
  1. Jan 28, 2024 at 7:54 AM
    #61
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I have heard a number people saying that the 3.5 has deceleration fuel cutoff (DFCO), but also that it might be disabled on those with the manual transmission based on OBD scanner info.
    In any case, I don’t think you are accomplishing much of anything related to cooling. The truck has a cooling system to take care of that for you. But if you want to know for sure, buy a OBD scanner to get better water temp info. Exhaust gas temp might be more interesting in your case, but I don’t think the taco has such a sensor. I could be wrong.
    One final thought… your analysis of air flow assumes that the pressure of the air inside the cylinder is the same during acceleration and deceleration which is not likely to be correct. When you close the throttle at high rpm you cause a low pressure situation in the cylinder.
    https://en.wikipedia.org/wiki/Ideal_gas_law
    GTGallop[QUOTED] and soundman98 like this.
  2. Jan 28, 2024 at 8:03 AM
    #62
    GrandMasterChooch
    GrandMasterChooch Well-Known Member
    east coast
    snow tires
    Drive like a race car, expect race car problems.
    :spending:
  3. Jan 28, 2024 at 8:05 AM
    #63
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    So thank full for modern fuel and oils so I don't have to worry about that any more.
  4. Jan 28, 2024 at 8:26 AM
    #64
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Is it before? I honestly don't know.
  5. Jan 28, 2024 at 8:44 AM
    #65
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Fuel being cutoff at the de-accel. Short terms fuel trims are at 0.
    Lambda sensors report 1.23.
    intake valve timing is set to 30°, exhaust valve timing 0°, maf reports around 8-9 gm/sec at 66 mph/1600 rpms, trottle plate is set to 4°
    soundman98 likes this.
  6. Jan 28, 2024 at 8:56 AM
    #66
    Vlady
    Issy, WA
    MAF is between the air cleaner box and TB.
    Otherwise the whole system ain't gonna work.
    One note, it is closed loop EFI. The fuel compensation is done via lambda sensors, short and long fuel trims to maintain 1.47 afr
  7. Jan 28, 2024 at 10:12 AM
    #67
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Sure is. I guess getting to 0-60 in 7 secs is not good enough for some people.
    :facepalm:
    Irons, Canadian Caber and gudujarlson like this.
  8. Jan 28, 2024 at 10:16 AM
    #68
    gudujarlson
    Minnesota
    I think some people have neglected their morning calf exercises and have lost the ability to push the gas pedal to the floor. I’d never owned an automobile that could do 0-60 is under 10s before the taco.
    EDIT: I forgot about my 90’s Mitsubishi Mirage that could do it around 7s as well if I remember right.
  9. Jan 28, 2024 at 10:18 AM
    #69
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    :rofl:
    It really is a sad state of affairs…
    Phlogiston and soundman98 like this.
  10. Jan 28, 2024 at 10:30 AM
    #70
    Kolohe07
    Kolohe07 Well-Known Member
    David
    Haiku , Maui, Hi
    2022 Access cab Sport 4x4 Celestial Silver
    Recommended by The Car Care Nut, if you only drive around town.
    Irons and Canadian Caber like this.
