Is there really a 2018 Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GoLowDrew, May 12, 2017.
  1. Jun 16, 2017 at 3:38 PM
    #141
    TacoFister
    TacoFister Well-Known Member
    Josh
    2016 QS TRD 4x4 Off Road
    Worst maybe, still love mine. See PLENTY of new ones on the road and still out sell any other mid-size out there. just turned 20k in mine. Should probably get the 2nd transmission TSB done at some point.
    Spare Parts likes this.
  2. Jun 16, 2017 at 7:41 PM
    #142
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    I came to this sight to see the insights of 3rd gen now I think I should just do a rebuild of my dd but still will see the 18 before I fully decide. Currently my 93 Sr 5 sp 350k had it since new. But like the looks of the 3rd gen.20170428_090339.jpg
  3. Jun 18, 2017 at 6:16 AM
    #143
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    My first car was a 65 Mustang. Paid $250 for it, as it was old and in not great shape. I was a teenager working a a gas station- I asked the mechanic/ owner to look it over, and his one answer was, "it needs some work, but you will get back every dollar you put into it", he was spot on. Thought about this seeing your 93. If I was you, I would keep this and get another vehicle as a daily driver. I like my 3rd gen, but I needed a new truck when I bought it. You already have a truck for truck needs, so you have more freedom to go a different route if you want.
    All this is predicated on the frame being free of serious rust. Otherwise, get the 3rd gen. The SR 4x4 with 4cyl and 5 speed should make you pretty happy imo.
    Good luck and NICE 93!
    shakerhood likes this.
  4. Jun 18, 2017 at 9:04 PM
    #144
    Jckdnls
    Spicer, mn
    Dakar torsion bars
    Was going to keep the 93 n get rid of the dodge. Plans on turning the 93 into an overlander n put the 3.4 into her.
  5. Jun 19, 2017 at 5:31 PM
    #145
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    No...It's still June....they will not be made till August..!
    Hiluxski likes this.
  6. Jun 19, 2017 at 5:47 PM
    #146
    69others
    69others Well-Known Member
    2018 exactly like 2016 minus safetysense and color addition.
  7. Jun 19, 2017 at 5:51 PM
    #147
    over60
    Muskoka, Ontario
    What colours.?
  8. Jun 19, 2017 at 5:54 PM
    #148
    69others
    Cement was not in 2016.
  9. Jun 19, 2017 at 6:00 PM
    #149
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
  10. Jun 19, 2017 at 8:16 PM
    #150
    GoLowDrew
    GoLowDrew [OP] Well-Known Member
    The point of the thread is that does Toyota consistently make changes and improvements to the Tacoma? For example To point to the rear diff issue. If it came off the line today, is it torque to a different setting? Or will Toyota only apply the new torque settings on the 2018?
  11. Jun 19, 2017 at 8:45 PM
    #151
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    It depends. I think it matters as to what system the proposed change effects. An engineering team has to sign off on the change, and I am not privy to their project management, so a change order may sit for months in the drivetrain dept, but maybe only days in the suspension dept.
    So there is a process that has to take place, including weighing the cost of the change/update between model years. Some exec makes a decision and it rolls out in mid cycle or on the new MY truck
  12. Jun 19, 2017 at 10:45 PM
    #152
    Doubletap777
    Doubletap777 Active Member
    Toby
    Sacramento
    2017 Inferno Tacoma TRD OR DCLB
    I have a late build 2017. No issues, no recalls, no TSB's. I would guess they've rectified the diff issues.
  13. Jun 20, 2017 at 9:21 AM
    #153
    viking15
    viking15 Well-Known Member
    Joe
    I am like you. I plan to hold on to mine until 2020 and then trade her in. I hope by 2020 they get all of the problems ironed out. Right now the only problem I have is the howling diff.
  14. Jun 20, 2017 at 11:29 AM
    #154
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    They have not rectified the howling rear yet.
  15. Jun 20, 2017 at 1:06 PM
    #155
    Doubletap777
    Toby
    Sacramento
    Thanks, I'll keep my eye on it then. My Colorado went from a small howl to almost unbearable in one weekend trip. Dealer swapped out ring and pinion gears. Known issue on early models.
  16. Jun 20, 2017 at 1:10 PM
    #156
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Looking in the parts catalog, it seems there may be a number of updates for the 2018 based on what I'm seeing for end dates on the current parts. I expect a late start to 2018 (Nov. 2017 production). What those updates will be, I have no idea.
    Jeff
  17. Jun 20, 2017 at 1:48 PM
    #157
    GoHuskers
    GoHuskers Well-Known Member
    Nebraska
    2012 White DCLB TRD Sport
    2018 is open for Order now and expected delivery 10/2017.
  18. Jun 20, 2017 at 1:53 PM
    #158
    Jeff Lange
    Calgary, Canada
    Interesting. Didn't expect that with what I was seeing.
    Jeff
  19. Jun 20, 2017 at 1:56 PM
    #159
    GoHuskers
    Nebraska
    Here you go
  20. Jun 20, 2017 at 2:02 PM
    #160
    Jeff Lange
    Calgary, Canada
    No I believe you, it's just interesting. If both that and the parts catalog are correct, it looks like some of the changes I was expecting may happen after 2018 production begins.
    Jeff
