Is There Settings for the Auto Roll Down Window
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Speaks05, Nov 12, 2020.
  1. Nov 12, 2020 at 6:50 PM
    Speaks05
    Speaks05 [OP] Well-Known Member
    Christopher
    3rd Gen TRD Sport DCLB
    My drivers side window just recently started only rolling half way down when I press the window button one time, it goes back up fine and the passenger side is still operating normally, I looked in the dash settings and radio settings to see if there was an option to change it and I did not find anything.
    If anyone has an idea what it could be or how to fix it I would be much appreciative. Thanks in advance.
  2. Nov 12, 2020 at 6:53 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I don't believe there's a setting. Does the window continue to roll down after?
  3. Nov 12, 2020 at 6:58 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Press the window switch down and hold all the way for 10 seconds. Then all the way up and hold for 10 seconds. Then try one click down to see if the automatic windows work.
    hiPSI, Malvolio, Chew and 1 other person like this.
  4. Nov 13, 2020 at 7:49 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The switch should have 2 up and 2 down positions, the first position allows you to manually stop where you want and the 2nd full press is the automatic.
  5. Nov 13, 2020 at 10:27 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Take a look at the attached file and see if that helps.
  6. Nov 13, 2020 at 1:41 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    What year truck?? If it's still under warranty, make the dealer do it!
    If not, THEN listen to the TW gurus.
    G.
