Is there supposed to be any kind of oil/grease inside the tie rod boot or is my rack leaking?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andrew61987, Jul 28, 2021.
  1. Jul 28, 2021 at 5:38 PM
    andrew61987
    andrew61987 [OP] Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I noticed my tie rod boot has torn and there is some kind of grease or liquid seeping out and occasionally leaving a drop on the driveway. Do I need a new rack or can I just change the boot?
  2. Jul 28, 2021 at 5:39 PM
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    Its leaking.
  3. Jul 28, 2021 at 9:33 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Inner tie rod or outer tie rod? :anonymous:
    stickyTaco likes this.
  4. Jul 28, 2021 at 9:41 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    If there is liquid inside the boot, then your rack is leaking and needs to be changed/rebuild
  5. Jul 28, 2021 at 9:47 PM
    Bishop84
    Bishop84 Well-Known Member
    Its a worn rack, the boots are there to protect the joints, not retain fluid.
    You need a rack and pinion.
    TnShooter likes this.
