Is this a drive shaft problem ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Asgard, Nov 12, 2009.
  1. Nov 12, 2009 at 2:10 PM
    Asgard
    Asgard [OP] Well-Known Member
    06 PreRunner DC SR5 w/LSD
    For the past week I have this intermittent squeaking sound during acceleration from 0 to 25mph, like a slipping belt or a pulley going bad. Once I hit 35mph the squeak turns to a rumble and the truck starts to vibrate, when this happens I slow down and this only happens when I have my foot on the gas if I'm coasting downhill at about 40mph there is no noise or vibration. So now I'm driving around town at like 30mph, thank god for city traffic. Going to take the day off tomorrow and try and figure it out, what do you guys think ?
  2. Nov 12, 2009 at 2:18 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    does it vibrate under acceleration,if so does it stop[vibrating] when you take your foot off the gas?
  3. Nov 12, 2009 at 2:20 PM
    Asgard
    Noise and vibration under acceleration only, everything is gone when I take my foot off the gas.
  4. Nov 12, 2009 at 2:24 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    its probably your universal joints.
  5. Nov 12, 2009 at 2:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2. Or Carrier Bearing.
  6. Nov 12, 2009 at 2:39 PM
    Asgard
    Is there anything I can do to pinpoint which one it is (bearing or universal joint) ?
  7. Nov 12, 2009 at 2:54 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    craw under your truck and at the front of the rear drive shaft is the carrier bearing.try wiggleing it around.it will have a little movement but if its out it should move alot.that will eliminate that.to check u joint,try the power brake trick.u put it in gear,give it a little gas(dont floor it)and listen for a ping sound.try it forward and backwards without moving the truck.if u get a ping sound u got u joint problems.good luck
  8. Nov 12, 2009 at 2:56 PM
    Asgard
    ^^ Thanks, I'll do this tomorrow.
  9. Nov 14, 2009 at 7:22 AM
    Asgard
    Well the drive shaft looks ok. My friend who was helping me suggested we do the same thing as pataco said, we even put the truck rear on stands and I accelerated to 50mph. No noise or vibration. Now I'm thinking it's bad tires, the squeaking sound could be a 'body noise' because of vibration from the tires. Gonna get some new tires on Monday.
  10. Nov 16, 2009 at 2:27 PM
    Asgard
    ok, you guys were right. I had a mechanic put it up on a lift and he inspected the drive shaft and told me I need a u joint. The one to the front. Can someone cofirm this part number 04371‑04030 ?
  11. Nov 16, 2009 at 2:35 PM
    ikataco
    ikataco Well-Known Member
    06 DC Sport
    When on a lift or jackstands, there's no load on the drivetrain, therefore can't duplicate the cause = noise.
  12. Dec 2, 2009 at 9:38 PM
    baldy77
    baldy77 Well-Known Member
    Albuquerque, NM
    05 TRD Offroad Doublecab Speedway Blue
    3" Toytec Adj Coilovers w/Bilstein 5100's front and rear, Toytec TSB AAL, LR UCA, Avid Weld-on Sliders, A.R.E. CX Topper.
    How many miles did you have on your truck when you began having these issues? also, is your truck stock or lifted?
  13. Dec 3, 2009 at 1:07 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Next time all you have to do is grip the driveshaft and turn it. You'll know immediately. You shouldn't have any play whatsoever. Wiggling was a bad word for it I think, or he would have found it.
  14. Dec 3, 2009 at 6:20 AM
    Asgard
    50k miles and my truck is stock.
  15. Dec 3, 2009 at 7:35 AM
    JAG
    JAG Well-Known Member
    Do you have the crappy rugged trails... they seem to cause probs when they wear down... (i.e bumpiness)
  16. Dec 3, 2009 at 10:05 AM
    Asgard
    Wasn't the tires after I changed the u-joint everything was ok. Also when they removed the old u-joint it was missing a cap.
  17. Dec 3, 2009 at 10:06 AM
    Asgard
    U-joints are sealed, they cannot be greased. At least on the PreRunners.
  18. Jul 20, 2013 at 8:05 AM
    HOOTERBIRD
    HOOTERBIRD Yeah You Right !
    NOLA
    2013 DCSB TRD Sport, 4X4
    How much did he charge you to fix it?
