Is this a good deal for this Alpine amp?
Discussion in 'Audio & Video' started by rod11, May 1, 2009.
  1. May 1, 2009 at 12:14 PM
    rod11
    rod11 [OP] Well-Known Member
    Baton Rouge, LA
    09 Pyrite Mica DC Prerunner TRD Sport
  2. May 1, 2009 at 12:19 PM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    That is one of the original vpower amps. They were good and probably still are. 100 dollars may be a little high. Its one of those things that if you were buying it from a friend and knew it to work well, id do it. But an amp that old from a stranger may not be worth it.
  3. May 1, 2009 at 3:48 PM
    81shark
    81shark Well-Known Member
    i'm sure you can track down a harness. if you have an aftermarket head unit, you can use the rca cables.
  4. May 1, 2009 at 4:32 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Yeah you don't need the harness if you're going aftermarket. Most all aftermarket decks have lineout RCA's to plug into it.
    Vpowers are good amps, that one is old though, don't know much about it. Guys askin a little much though.
  5. May 1, 2009 at 7:39 PM
    rod11
    Baton Rouge, LA
    Thanks for the advice everyone. I didn't buy it. I didn't realize it was such an old amp.
  6. May 1, 2009 at 9:04 PM
    brian
    Elizabeth City, NC
    If you want yourself a trustworthy old amp... go find a Phoenix Gold. IMO the old ones from the 90's are some of the best amps you can get ahold of!
