Is this a good lift option from Toytec for my 01 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by prerunnerSD, Jul 12, 2011.
  1. Jul 12, 2011 at 1:53 PM
    prerunnerSD
    prerunnerSD [OP] "I Brake for Tailgaters"
    Northeast USA
    01 Tacoma Limited 6 cylinder 4X4
    Grill guard Front and rear Bilstein 5100's Front Coilovers Rear AAL "I Brake for Tailgaters" Firestone Destination A/T (P265/75/R16)
    bit of a newbie here I just got a nice 01 Tacoma V6 4X4 TRD Limited and I want to change the front and rear shocks and add 2-3" lift..I called up toytec and they quoted me $619 for all the following parts:
    Bilstein 5100 height adjustable front & rear 5100s for $349 total
    Toytec/Eibach front coil lift springs for $149
    Front Differential Drop Kit $29
    Rear ToyTec Add-A-Leafs $79
    Brake Proportioning Valve Bracket Kit $9
    Is this a good setup and price? Am I miss anything or did they add anything on that I dont really need. Not looking to break the bank here.
  2. Jul 12, 2011 at 2:19 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Looks like the same set up that's been proven effective countless times on here. I'd say you're good except you might look at some extended brake lines. My rear end is lifted 2" and the lines are pretty tight at full flex.
  3. Jul 12, 2011 at 2:48 PM
    prerunnerSD
    Northeast USA
    OK so thats reassuring.. where do i order longer break lines? Would toytec sell those? Also for the price this option is more affordable, would it also be a good solution?? don't want to cut corners but don't wanna break the bank.. what would the pros and cons be for going with this method
    FRONT: 3" Front Lift Spacer Kit-- CNC Machined From 6061 T-6 Aluminum - includes (6) longer top plate spacer studs.
    REAR: (2) 2" lift ToyTec Rear Add-A-Leafs --
    Offering OEM Style anti-friction Pads, these are a long add-a-leaf for the best ride.
    New extended length rear ProComp 9000 Nitrogen gas charged shocks, or add Bilstein zinc plated 5100 extended length rear shocks; choose from options below
    New Leaf Spring Center Pins,
    Brake Proportioning Valve Extension- needed to gain the correct brake proportioning back to the rear when lifting your rear suspension. Install Directions.
    *** NOTE: Will not work on the 5-Lug Tacoma.
    Is my Taco a 5 lug?
  4. Jul 12, 2011 at 2:52 PM
    n315on
    n315on Well-Known Member
    MA
    02 4x4 SR5
    3'' toytec lift springs wrapped around 5100's. Deck plate mod. TRD seat belt pads. JL audio amps /subs and Alpine speakers. Diff breather mod. Working on a custom rear bumper
    Id go with the first option
  5. Jul 12, 2011 at 2:53 PM
    prerunnerSD
    Northeast USA
    hey, n315on
    your in MA! Where would you go to have these parts installed?
  6. Jul 12, 2011 at 2:56 PM
    dbronzo
    dbronzo Protected by Armor Tech Offroad
    Dennis
    Fayetteville, NC
    08 TRD Sport 4x4 w/ some Mods
    King Coilovers, LR UCA's, All Pro Sliders, ATO Full Skids, Pioneer AVH-P4300, 4.56 Gears, Front and Rear ARB Air Lockers, ATO Full Wrap High Clearance Bumper w/ Tire Carrier, ATO Hybrid Bumper, Smittybuilt XRC 8, Lightforce 240 Blitz, Rock Lights
    If you plan on wheeling it check the rear shock part number. The ones that usually come with the kit have minimal travel.
  7. Jul 12, 2011 at 3:01 PM
    jbrandt
    jbrandt Well-Known Member
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    King ext travel coils Total Chaos UCAs Sticker mod
    If it's a 4x4, no. "lugs" are how many lug nuts each wheel has. 4x4 and pre-runners have 6, 2x4's have 5.
    As for, "is this a good lift?" I don't know. What are your intended uses for it? Mall Crawler? Trailer Queen? Occasional off-roader? Or a serious off-roader?
    If you're going to do some more serious off roading (or even IMO, occasional wheelin') DON'T get spacer kits and add-a-leafs. Those, IMO, are for mall crawlers. All they do is make your truck higher for bigger manly tires. If you will wheel with it, you'll want added benefits of increased travel, etc... that come with other lift styles.
    A good "minimalist" kit that will give you some added performance and height, go for the Bilstein 5100 adjustable shocks in the front and match that with 5100's in the back and either new shackles or better yet, a new leaf pack will get you 2.5" lift.
    An all out IFS setup would be the Total Chaos 14" travel kit for the front, and custom leafs for the rear.
  8. Jul 12, 2011 at 3:02 PM
    jbrandt
    Sacramento, CA
    if you're somewhat handy with a wrench, you could do all that yourself. Most kits come with pretty good instructions, and this site has a wealth of knowledge, too!
  9. Jul 12, 2011 at 3:09 PM
    n315on
    MA
    02 4x4 SR5
    I put them on myself and my truck rarely sees a shop, so i have no clue where you could take it.
    Although I would suggest researching the installation of these parts and doing it yourself. It's good to learn how to work on your truck if you plan on wheeling and also saves a bunch of $$$$
    And like I said go with your first option, I went the Spacer route (second option) and ended up with the bilstiens and eibach's in the end.
  10. Jul 12, 2011 at 3:13 PM
    n315on
    MA
    02 4x4 SR5
    Also, IMO i think diff drops are useless. So id scratch that idea and maybe hold off on the AAL for now and save up for some deavers or the like.
  11. Jul 13, 2011 at 9:11 AM
    prerunnerSD
    Northeast USA
    well the diff drop isnt too expensive but what are deavies??? any chance you could teach me how to install this stuff... no half wit here.. just dont have the space to really get down and dirty under my truck if you know what i mean
  12. Jul 13, 2011 at 9:16 AM
    prerunnerSD
    Northeast USA
    Ok so I'm set on getting the 5100s... The truck will be more or less an on road truck with some occasional off roading for camping and such but with the winters up here being so harsh and NY and Boston roads being what they are I think you NEED a truck up here! what kind of leaf or shackle kit do I get and do I need any additional options for that.. should I also be setting the 5100's at a higher length for more travel?
  13. Jul 13, 2011 at 12:49 PM
    jbrandt
    Sacramento, CA
    With out any other fron suspension mods, you won't be getting any more total travel. Basically, you lower the A-arms (lifting the truck) giving you less down travel, but more up travel. Low profile bump stops are an easy way to squeeze a bit more travel out, but bottoming out with be much more harsh.
    The 5100 "kit" from DSM I'm pretty sure the rear shocks are sized so that you can either keep the stock height, or (with a spring/shackle lift) get up to 2.5" lift without over extending the shocks. That's what attracted me to it so much. I'm not planning to lift my truck, much if at all...
    As for a rear shackle lift, Toytec makes one for ~$90. They're basically just longer than stock shackels that give ~2" lift.
    http://www.toyteclifts.com/index.ph...tegory_id=122&option=com_virtuemart&Itemid=72
    Add-a-leafs are pretty cheap too, but I generally don't prefer them because they just make the ride stiffer. You might think about a custom leaf pack from Alcan or something.
    I used to sport a '86 Turbo 4Runner. I set up the rear leafs with the top two leafs from a Mazda 2wd pickup, and the rest the stock springs. It gave a few inches lift, but mainly increased the travel because the mazda springs were so much longer. I got some OEM front spring mounts and welded them right in front of the old stock ones, and used 2 or 3" longer shackles = ~25" travel in the rear.
  14. Jul 13, 2011 at 1:28 PM
    mountainman94
    mountainman94 awwwwww yeeeeeeeeahhhhh
    Cory
    A Place of Higher Learning
    '98 TRD SR5
    5100's/Eibach coils; 2 inch toytech AAL, Black Pacer 15x8 wheels, 32x11.5 BFG AT K/Os
    That top set with the 5100's looks like what i'm looking at. If you end up putting it on, i'd like to see/hear how it works for you.
  15. Jul 13, 2011 at 1:34 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
  16. Jul 15, 2011 at 4:42 PM
    n315on
    MA
    02 4x4 SR5
    Deaver's http://www.deaverspring.com/products/leafstoy.html Where abouts in MA are you located?
  17. Jul 15, 2011 at 6:13 PM
    prerunnerSD
    Northeast USA
    Thanks for the link.. The term Deavies seems to be coloqual however.. Toytec and other merchants do not know a direct translation or application. I'm in eastern mass.. But don't be detered if I'm far from your recogmendarion.. Its a small state.. When scaled on a map the word 'Massachusetts' doesn't even fit in its bounderies. My usual mechanic in Waltham, Franks Auto, is great. So great and so busy he has no time to call me back so willing to be flexible on an alternative.
  18. Jul 17, 2011 at 5:58 AM
    dustinuhls
    dustinuhls Well-Known Member
    Manhattan, KS
    '01 Limited DoubleCab 4x4
    3" SL, Nerf Bars, 33" BFGs, K&N, Deckplate, Royal Purple
    I have the same '01 Limited (Doublecab) Taco as you. I put on the ToyTec 3" front coil spacer and rear add-a-leaf about 6 years ago. Never had a problem with it and kept the stock Bilstien shocks. I'm running 285/75-16s on it now. No issues with rubbing. I don't do any serious off-roading with this truck anymore, so the lift was mainly to fit some bigger tires. It just depends on what you want to use your truck for.
