Is this a good price for work
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaislife, Aug 31, 2020.
  1. Aug 31, 2020 at 2:32 PM
    Tacomaislife
    Tacomaislife [OP] Well-Known Member
    Texas
    2002 tacoma trd
    Valve cover gaskets - Part #11213-62020 - 2 Total
    2. Spark Plug Tube gaskets - Part #11193-16010 - 6 Total
    3. Intake Plenum Gaskets - Part #17176-62040 - 2 Total
    4. Washer Seals - Part #90210-05007 - 16 Total
    5. Camshaft Plugs - Part #11188-62010 - 2 Total
    6. Halfmoon Plugs - Part #11183-62010 - 4 Total
    7. PCV Valve Grommet - Part #90480-18001 - 1 Total
    8. Spark plugs and wires . 9.fuel filter replacement. 10.transmission filter exchange and replaced pan with new one all that for 600 just labor is that a good price for just labor
  2. Aug 31, 2020 at 2:50 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Seems fairly reasonable for removing the valve covers and dropping the trans pan.
    Are all those things bad, or are you just going around replacing a bunch of gaskets?
  3. Aug 31, 2020 at 2:59 PM
    gasgasman
    gasgasman Well-Known Member
    Girard
    Texas
    All Data labor times:
    Both valve cover gaskets. 2.9hrs
    Intake manifold gaskets. 3.6hrs.
    Trans filter. 2.8hrs
    So, $600 sounds reasonable.
  4. Aug 31, 2020 at 3:03 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'd skip the pan drop. A drain of the fluid will remove 90 percent of the particles on the screen ( it's not a filter) when the fluid back flushes out the drain plug.
    TWJLee, Rachelsdaddy and cruiserguy like this.
  5. Aug 31, 2020 at 3:14 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    The thing is I did just drain the fluid but I over tighten it and it messed up the threads and started leak I did try to take of the bolt but it just keeped on spining
  6. Aug 31, 2020 at 3:16 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    Valve cover is leaking and transmission bolt the threads are messed up and just keeps on spining and it's leaking so I might as well change everything
    jammer and gasgasman like this.
  7. Aug 31, 2020 at 5:13 PM
    koditten
    Kirk
    Central Michigan
    Then yes, $600 is a good price.
    Be aware that they are going to ask if they can change the transmission pan because of the messed up drain plug threads. That could get spendy.
    Rachelsdaddy likes this.
  8. Sep 1, 2020 at 2:11 AM
    Tacomaislife
    Texas
    2002 tacoma trd
    Yeah I kinda already bought a new one lol but could I retap the old one and have it in case something like this happens again
    koditten[QUOTED] likes this.
  9. Sep 1, 2020 at 11:16 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The $600.00 in labor is not bad the bottom line is if your happy with the end results.
    If things are done incorrect or poorly even $300.00 is to much.
