Is this a inner or outer Tie Rod?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SubFrozen, Nov 25, 2010.
  1. Nov 25, 2010 at 5:51 AM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    3" OME Heavy Duty Lift, 18" Chrome Rimes, ARB Front Bumper, K&N Cold Air Intake
    When replacing my CV Axles, I popped this baby out, then broke the boot trying to get it back on, and messed up the threads. It's on, but not completely, which means at any time it'll come flying off, causing me to go careening out of control on the freeway. Is this an inner or outer tie rod end, and, what's a good replacement? Also, what the heck tool do I use to get it back on, it just spins and spins and spins.
    *Edit -I really don't know what part it is.
  2. Nov 25, 2010 at 6:18 AM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    That's the sway bar link
  3. Nov 25, 2010 at 6:20 AM
    xxaarraa
    xxaarraa Well-Known Member
    Yes, sway bar end link. You could use a needle nose vice grip to keep it from spinning.
  4. Nov 25, 2010 at 6:34 AM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    Tried, slipped, broke the boot.
    Alright, sway bar end link. Time to find a new one, any suggestions?
  5. Nov 25, 2010 at 8:40 AM
    xxaarraa
    I had the same problem. You have to use needle nose vice grips, not enough room for regular vice grips. I broke the boot too, just hit the crack with some rubber sealant. Sway bars are a non-critical component, I wouldn't sweat it too much. If you really want, you could get a new end link for pretty cheap.
    I had a Ford Ranger that had a sway bar end link fall off and I drove it like that for thousands of miles.
  6. Nov 25, 2010 at 8:42 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Do you have one or both tires off the ground? Cause I remember that bastard spinning too. In the end I remember putting one or both tires on the ground, (Just one I think) and that causes the sway bar to torque putting pressure on the link and the spindle which stops it from spinning.
    That and an Impact wrench fixed that fucker good.
  7. Nov 25, 2010 at 8:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Not sure why you guys are using pliers, and such. THe end links have a hole on the end of the threadded shaft that accepts a 5mm (iirc) hex wrench to hold it from turning.
  8. Nov 25, 2010 at 8:54 AM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    06 TRD Prerunner
    Stop clouding the issue with facts......... :D
  9. Nov 25, 2010 at 8:57 AM
    JKD
    JKD Well-Known Member
    The handling is significantly different between a vehicle with a sway bar attached and one without one or with one disconnected.
    It may not be critical in a straight line, but it can be critical if you are doing fancy avoidance maneuvers.
  10. Nov 25, 2010 at 9:12 AM
    04LTtacoma
    04LTtacoma Well-Known Member
    Outer Space
    Someone posted before me and told yah! If I was the first one to see this post I couldn't tell you. Not familiar with the newer tacomas.
  11. Nov 25, 2010 at 9:24 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    If you dont know the difference between them..should you be messing with them at all? Just a thought
  12. Nov 25, 2010 at 9:41 AM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    Bah, where's your sense of adventure? There's always room for more knowledge by messing stuff up ;)
  13. Nov 25, 2010 at 9:44 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    That's what I figure, but I just get mocked for it.
    BTW, tranny fluid isn't coolant isn't oil. Just FYI.
  14. Nov 25, 2010 at 9:45 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont think you need to know the name of a part, in order to remove it.
  15. Nov 25, 2010 at 9:46 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
