Is this a sign of a Head Gasket leak?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RockfordTaco2006, Sep 23, 2023.
  1. Sep 23, 2023 at 9:32 AM
    RockfordTaco2006
    RockfordTaco2006 [OP] Well-Known Member
    Alexander
    2006 Toyota Tacoma TRD Off Road 4x4
    2 Inch Lift
    So I've had my truck parked waiting for body parts. I ran the truck up to temp a couple times this year after fixing the radiator. I topped off the coolant reservoir and it's been sitting about 6 weeks since the last time I ran it.
    Today I pulled the tarp off and noticed the coolant level has dropped in the reservoir about an inch. There are no noticeable leaks. Is this normal would there be pressure in the lines still to suck the fluid into the system?
    Is the coolant going into the engine like a head gasket leak I wonder?
    Should I start her up today?
    Any advice would be appreciated....Thanks
  2. Sep 23, 2023 at 9:42 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Could have been some air in the system that came out. As for a head gasket leak, did you check the oil to see what it looks like?
    RockfordTaco2006[OP] likes this.
  3. Sep 23, 2023 at 9:45 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Is oil “milky “ looking
  4. Sep 23, 2023 at 10:02 AM
    4x4spiegel
    4x4spiegel Well-Known Member
    do a simple block test
  5. Sep 23, 2023 at 10:16 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Air pocket?
    What was the air temperature when it was filled versus the current air temp? Mine overflow level changes between summer and winter temps.
  6. Sep 23, 2023 at 10:56 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The milkshake thing isn't really a thing on newer engines, that's a throwback to old cast iron pushrod engines
    Block testing doesn't really work on these engines either.
    After sitting for so long it's possible the coolant level could contract a ittle more than usual, pulling the level down in the res. Don't hit the panic button yet, just start driving it again and keep an eye on the level. If you're really that worried about coolant in cylinders sure pull some spark plugs and turn it over but personally I wouldn't worry about it. If it didn't have any signs of coolant loss or overheating before it got parked it's probably fine. A head gasket can't pop a leak just from sitting..
  7. Sep 23, 2023 at 11:02 AM
    RockfordTaco2006
    Alexander
    2 Inch Lift
    Yeah.... I panic'd a bit, and couldn't find a quick search with this symptom, sorry ....oil looks good on the dip stick but it's due for an oil change. The weather was hotter when I topped it off and it much cooler out now.
    Thanks everybody!
    I'll probably do that oil change today and see what it looks like there.
  8. Sep 23, 2023 at 5:26 PM
    RockfordTaco2006
    Alexander
    2 Inch Lift
    Ok I changed the oil. It looked fine. I ran it up to temp and it cooled fined so i think I'm ok.
    Thanks so much for the peace of mind.
  9. Sep 23, 2023 at 8:32 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    You are fine O.P, you are overthinking a non problem.
    Drive the truck and enjoy.
